Does my vortech need a rebuild?
Old Jun 18, 2010 | 08:14 PM
zeer0's Avatar
zeer0
Default Does my vortech need a rebuild?
Hi Guys,
Noticed that there has been a large amount oil spray and dirt accumulation around my SC area and decided to take it apart to take a look. I could not tell specifically if any area of the SC was leaking, but I'll let you guys be the judge from the pics. From what I can tell there is no play on the impeller bearings, so if I were to get a rebuild, I plan to send to 928 motorsports for a rebuild on the seals. So let me know what you guys think, do I need a rebuild?
Old Jun 18, 2010 | 09:28 PM
GT-ER's Avatar
GT-ER
My car does the same thing...it runs fine though.
Old Jun 19, 2010 | 05:38 AM
05Z33's Avatar
05Z33
Check the area around the cog pulley to see if the seals are leaking. They may just need to be replaced. If it's leaking and you let it go on like that, your bearings will eventually fail. Also my BPV looked the same as yours full of oil. I made a CAI for the blower and placed a breather filter on the back driverside valve cover. This fixed the problem until my bearings failed. Then the BPV got real dirty as well as my pipes and intercooler.
Old Jun 19, 2010 | 05:44 AM
GT-ER's Avatar
GT-ER
I my case the blower sounds fine ( I think..lol ) but it does leak some oil into the charge pipes. I'll just leave it like that till it fails and then I have an excuse to upgrade.
Old Jun 19, 2010 | 10:22 AM
Vas_Z33's Avatar
Vas_Z33
rebuilt it asap.. thats not normal.. you have way too much oil around the bpv and pipes.. a little is fine and normal.. but you got a lot more.
I would rebuilt it.. if you let it stay longer.. itll get worst.. it wont get better.
Old Jun 19, 2010 | 11:13 AM
zeer0's Avatar
zeer0
Checked the seal under the cog and it is fine, no signs of oil. At this point, still not very sure where the oil spray is coming from.
Old Jun 19, 2010 | 11:29 AM
05Z33's Avatar
05Z33
Check your sway bar. If it's covered in oil it's coming from your BPV. Send it out for rebuild to be safe. The folks at 928 will take care of you. You can also check with Superchargerrebuilds.com.
Old Jun 19, 2010 | 06:38 PM
GT-ER's Avatar
GT-ER
In my car the sway bar is clean and so is the surrounding area. It's just the BPV that's kinda oily and so are the pipes. It's been like that every since I installed it though and really hasn't gotten any worse....yet...lol. I also don't have any exterior leaks.
Old Jun 20, 2010 | 05:42 AM
05Z33's Avatar
05Z33
If you are using the stock air filter it might just be blow by.
Old Jun 20, 2010 | 05:54 AM
GT-ER's Avatar
GT-ER
I don't have the PCV hose connected to the filter.
Old Jun 20, 2010 | 10:40 AM
zeer0's Avatar
zeer0
No oil on my swaybar either. I will try to reinstall the blower today and add a crankcase breather filter to see if it helps.
Old Jun 21, 2010 | 12:33 PM
Netacoma2003's Avatar
Netacoma2003
My PRV does the same thing. The left front wheel gets dirtier than the right front because the PRV is pointing that direction and since I'm an automatic, the PRV is always hissing/whining unless I'm at WOT when it closes completely.
Been that way since original install and tune but seems to run just fine and is putting out a little over 400rwhp.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
