Cipher
Old Jun 20, 2010 | 07:35 PM
thom000001's Avatar
thom000001
Default Cipher
Figure I'm most likely to find someone in here with one...
Wondering if anyone has a Cipher USB cable unit that I can borrow (not the osiris).
I want to make a single change in my ECU and don't want to buy the darn thing just for that.
If anyone has one they would ship to me and let me borrow (I'll cover shipping and whatever you want for me to use it)......
just lemme know...no one on chicagoz seems to have one.
Thanks,
Tom
Old Jun 20, 2010 | 08:16 PM
R350Zz33's Avatar
R350Zz33
dont only the cables work with one ecu
Old Jun 20, 2010 | 08:22 PM
thom000001's Avatar
thom000001
There website isn't super clear, but from old posts on here it doesn't sound like if....for the Cipher.
For the Osiris, you would be correct though.
Tom
Old Jun 21, 2010 | 02:06 AM
wannabuy350z's Avatar
wannabuy350z
Chiper can work on any ECU to clear codes and adjust idle. and clear fuel trims.
Old Jun 21, 2010 | 04:56 AM
Glex25's Avatar
Glex25
^I Think he is asking about the cable.
I wonder if the USB to OBDII cables on ebay would work
Old Jun 21, 2010 | 05:52 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
what change is it you need to make?
Old Jun 21, 2010 | 06:27 AM
thom000001's Avatar
thom000001
Just need to bump the idle a touch.
Tom
Old Jun 21, 2010 | 06:55 AM
str8dum1's Avatar
str8dum1
Good luck finding one. Cipher will work on any car and wil bump ya 250 rpms over stock so ~850. If you need any higher than that, you'll need a reflash.
Old Jun 21, 2010 | 08:28 AM
ashtrojan2008's Avatar
ashtrojan2008
i have one of those, works great to monitor oem sensors and stuff as well as clear codes/fuel trims,
but its just a scanner, won't adjust idle or anything like that.
i think the cable is too slow to work with osiris or something anyway.
do you know anyone with an accessport? i plugged my friends' up to my car and it seemed like it would adjust the idle on any z/g, as well as a global timing change and only the full map was ecu locked. i may be wrong though.
ross
Old Jun 22, 2010 | 07:00 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Tom
Tom, maybe try posting in your regional forum, and see if someone local can meet up with you.
Keep in mind the idle bump is only 250RPM,and only works on earlier gen ECU's from the 03-04's, and a handful of 05's.
Old Jun 22, 2010 | 07:14 AM
thom000001's Avatar
thom000001
I'll try on here to (for regional)....but I posted on chicagoz.com and no one does....ugh....
I just need like 800-850rpm for the idle, nothing crazy...
And I have an 04 (woohoo!)
Thanks,
Tom
Old Jun 22, 2010 | 03:34 PM
wannabuy350z
if you run out of luck, you can go to the dealership and via the consul II they can up your rpm.
Old Jun 22, 2010 | 08:30 PM
GreenGoblin's Avatar
GreenGoblin
Tom you can borrow mine. Pm me
Old Jun 22, 2010 | 09:05 PM
cersoft's Avatar
cersoft
I also have one that you can borrow for an extended period of time given that I never use it
Old Jun 22, 2010 | 10:33 PM
Mr_pharmD's Avatar
Mr_pharmD
can it clear codes and stop them from popping up again or will the codes keeping coming back?
Old Jun 22, 2010 | 10:47 PM
cersoft's Avatar
cersoft
Cleared codes will be back within 50ish miles ...
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Mike@Altered
Tuning
127
Nov 11, 2006 11:28 PM
