does mileage matter to put turbo??
Old Jun 26, 2010 | 08:54 PM
whiteangel1381's Avatar
whiteangel1381
Default does mileage matter to put turbo??
i have 2006 m/t 350z planning to go turbo but does mileage matter in order to put turbo?like what if i have 150 k miles then what shall i do?
Old Jun 26, 2010 | 08:59 PM
Frosty87's Avatar
Frosty87
Normal wear on motor. Motors only last so long without a rebuild if you Turbo your car at 150k I would imagine it would blow
Old Jun 26, 2010 | 09:21 PM
Vas_Z33's Avatar
Vas_Z33
some blow up at 10K miles.. some blow up at 100K.. some dont even blow. every car is different. Boosting a Z will put stress to your motor. It all comes down to if you have money to rebuild once it does blow. Always plan ahead. gl.
Old Jun 26, 2010 | 10:29 PM
Litesung's Avatar
Litesung
Well said, Vas
Old Jun 26, 2010 | 11:31 PM
wannabuy350z's Avatar
wannabuy350z
Rebuild. even if your shortblock is good, i am sure your heads need to have a vavle job at minimum. good luck!
Old Jun 26, 2010 | 11:55 PM
SlideFox's Avatar
SlideFox
The turbo doesn't blow your motor..... you do.
Old Jun 27, 2010 | 09:32 AM
thatv35guy's Avatar
thatv35guy
90k miles...turbo goes on next week....I no scare.
Old Jun 28, 2010 | 10:30 PM
boostedmaxima's Avatar
boostedmaxima
Compression test, if it comes back good, boost. Always be prepared though, have a back up sourced if this is your only car.
Old May 14, 2011 | 07:50 AM
Its mandatory for all members to say “Im going turbo.”
Old May 14, 2011 | 08:38 AM
steven350's Avatar
steven350
70k miles on the motor, i decided to rebuild it...a fresh start... like it was said b4, as long as you have the money for it..
Old May 15, 2011 | 05:49 PM
chrisjersey06's Avatar
chrisjersey06
Get a good tune, don't crank up the boost. There's no real reason it should blow unless its driver/tuner error. The same things that will blow a 150k mile motor will blow a 10k mile motor. People thinking they can push the limits just because they have low mile engine are the ones that run into trouble.
Old May 19, 2011 | 07:17 AM
djcetra's Avatar
djcetra
I don't plan on going turbo on my Z until I reach about 150,000 miles. However, I'm going to rebuild or buy a built engine to swap first
I don't think I'd feel safe otherwise.
Old May 19, 2011 | 07:50 AM
Cass007's Avatar
Cass007
you must be real bored today... just bumping old build threads to check dreamer status
Old May 19, 2011 | 06:57 PM
xzotklr's Avatar
xzotklr
You will need to build the motor along with the forced induction set-up.
Any serious levels of boost will wreak havoc on a 150k mile motor!!!
Don't try to go cheap, this is not a cheap man's game. DO IT RIGHT....OR DO IT TWICE!!
Old May 27, 2011 | 10:33 PM
ddc665350ztt's Avatar
ddc665350ztt
I like that last line.
But i really hope this dude isnt going to try and rebuild his own motor. Or install a turbo kit. if he doesnt even know the concepts of wear and tear. thats scary...
Mattg350z
Oct 2, 2015 06:51 AM
