Traces of a turbo/sc kit?
Old Jul 5, 2010 | 05:44 PM
350zsunshinefl's Avatar
350zsunshinefl
Default Traces of a turbo/sc kit?
Hello everyone, I am a former Z owner, this time around I am purchasing a 350z for my daughter, we are looking at a few 07's,
I am under the impression that one of them was heavily modded, what should I look for in the engine bay aside from obvious things like painted bolts with stripped paint?
Old Jul 5, 2010 | 06:04 PM
Ruthless18x's Avatar
Ruthless18x
Holes, marks, wires, etc, in the interior from gauges or a controller would be easy to find.
Old Jul 5, 2010 | 07:32 PM
tylerxfire's Avatar
tylerxfire
if ur really concerned with that look around the wiring for the ecu, or like said places where gauges would be wired in the fuse box or where wires would be ran throught the dash or grommets..whats on the car that makes you wonder?
Old Jul 6, 2010 | 07:17 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Might not find much around the ECU, most EMS nowadays use some type of splitter or "patch" harness so you don't have to hack up the factory harness. I would look around the upper oil pan for any plugs that may now be in place where an oil return may have once been.
Old Jul 6, 2010 | 02:35 PM
forced_04's Avatar
forced_04
^whathesaid
block plugs, or maybe the owner had a oil pan spacer so look at that and he might have left it on or of the oil pan has been redone and there is no service record of it.
just look to see if stuff like interior parts, the bumper, under tray, etc are loose or have mismatch bolts nuts popits. when someone does stuff at home they usually just make it work especially if they are selling it or trading it in.
Old Jul 6, 2010 | 02:50 PM
djamps's Avatar
djamps
Just do a compression test, and if you can also do a UOE. You'll know pretty quickly if the engine has been abused or not. Everything else is manageable.
Old Jul 6, 2010 | 06:28 PM
350Z400rwhp's Avatar
350Z400rwhp
New gasket material on the oil pan would be a good indicator for most kits.
Old Jul 6, 2010 | 06:34 PM
Brett@AwesomeZ
Good point, look for the sealant to be a different color than the stuff on the timing covers.
But yea, as someone else said, if the guy will let you get a compression test done that would be awesome.
EnjukuRacing
Sep 30, 2015 06:55 AM
