Greddy Twin Turbo tuned with Osiris at ZCar Garage
Old Jul 23, 2010 | 10:36 AM
mdcruz88's Avatar
mdcruz88
Default Greddy Twin Turbo tuned with Osiris at ZCar Garage
The car is fresh out of the shop and so far so good!
Rob did an awesome job of getting the car right. He ran into a couple of snags with the UpRev software, but he was able to will his way through it and come out on top with some pretty good results.
Specs:
VQ35DE
Greddy Twin Turbo 18g @ 8.38lbs of boost
RC650cc injectors
Fuel Return Line with drilled out fuel rail restrictor plates
Walboro Fuel Pump
UpRev Osiris
HPX MAF sensor
APS 2.5" true dual exhaust
Approx. 40k miles
Manual Transmission
91 Octane
Attached is the dyno and according to Rob it's a pretty conservative tune. Aggressive should be really interesting then. Also noteworthy is that the motor has a rattle emanating from the head which he suspects to be a loose shim bucket. We'll tackle that when we do cams...YEEEE!!
Attached Thumbnails Greddy Twin Turbo tuned with Osiris at ZCar Garage-350z-dyno.jpg
Old Jul 23, 2010 | 10:43 AM
thom000001's Avatar
thom000001
Nice,
6spd or Auto.
And is this on cali 91 oct?
Tom
Old Jul 23, 2010 | 10:48 AM
mdcruz88's Avatar
mdcruz88
Originally Posted by thom000001
Nice,
6spd or Auto.
Tom
Ooh that's right...updated!
Old Jul 23, 2010 | 11:07 AM
str8dum1's Avatar
str8dum1
looks good
how much more are you wanting to push on the stock block. doing cams seems pretty
silly unless you are fully building..
Old Jul 23, 2010 | 11:17 AM
IslandZavage's Avatar
IslandZavage
Congrats and enjoy. I love my Greddy kit.. I agree about the cams though. No point in just doing cams if keeping the stock bottom end as your pretty close to the considered safe zone of the stock block (400hp) anyways.
Old Jul 23, 2010 | 11:20 AM
cdoxp800's Avatar
cdoxp800
Very nice. Nice and safe. Enjoy your new found power.
Old Jul 23, 2010 | 11:23 AM
mdcruz88's Avatar
mdcruz88
Definitely agreed. Already hawking the marketplace for built long/short blocks. A steal of a deal is bound go pop up sooner or later!
I was considering working on traction first, but I never track and LA roads are terrible so...more powah it is!!!
Old Jul 23, 2010 | 11:51 AM
str8dum1's Avatar
str8dum1
^i'd read posts from people that have bought used motors. Failure rate is quite high.
Old Jul 23, 2010 | 01:49 PM
seymore4's Avatar
seymore4
Professional
Shouldn't have needed the HPX MAF sensor for those power levels..
Other than that looks like fun!
Old Jul 23, 2010 | 01:53 PM
djamps's Avatar
djamps
Stock MAF maxed out at 5psi by redline on mine...dunno where you got your info?
Old Jul 23, 2010 | 02:38 PM
ImWeeZzel's Avatar
ImWeeZzel
OP what psi did you have your car tuned to?
Old Jul 23, 2010 | 02:48 PM
djamps's Avatar
djamps
^^ shows 8.3psi on the dyno chart.
Old Jul 23, 2010 | 03:25 PM
ImWeeZzel's Avatar
ImWeeZzel
thanks guy^^^
Old Jul 23, 2010 | 06:29 PM
Elperuano's Avatar
Elperuano
Congrats on da new power... I was sure you'd get higher numbers n if im not mistaken it's a dynojet so reads higher than normal... Is the 91 octane really holding you back compared to 93 we have in FL?
Old Jul 23, 2010 | 08:26 PM
seymore4's Avatar
seymore4
Professional
I made 403 whp at 7psi on a dynojet with the stock maf..
Maybe they're all different
Old Jul 23, 2010 | 08:39 PM
- bigc -'s Avatar
- bigc -
^ it depends on what you use to tune. osiris relies on the stock maf, while some of the other platforms don't (maf is still being maxed out though).
OP, congrats on the results. drive the **** out of your car and enjoy it to the fullest
Old Jul 23, 2010 | 09:13 PM
seymore4's Avatar
seymore4
Professional
I'm was tuned with Osiris both times.. stock block and now with the built block and HPX MAF. Jus sayin, I didn't need the aftermarket maf and made 403 whp DJ. It is what it is.
This time around I'm using the HPX MAF and shooting for considerably more whp.
Old Jul 23, 2010 | 09:16 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
great numbers! Any pics of the Z?
Old Jul 23, 2010 | 09:19 PM
TheFarmer's Avatar
TheFarmer
Nice! I'll be in the bay soon. Want to check out Z Car Garage.
Old Jul 23, 2010 | 10:02 PM
- bigc -'s Avatar
- bigc -
hmm, very interesting then. for a while, folks have been trying to figure out why some MAFs max out while others don't. for the vortechs, at least, it has been whether or not the tune relied solely on the MAF or whether the ECU/piggy back/standalone got it's data from other sources (MAP sensor, vortech FMU using boost pressure to adjust, etc). if you were comfortably tuned over 400hp (how much boost, btw?) then it throws all that into question
