limits of stock VLSD
Old Jul 26, 2010 | 01:35 PM
seymore4's Avatar
seymore4
Professional
Default limits of stock VLSD
Just curious how many FI guys are running their stock VLSD (who have one)
My 2006 G35 came with the VLSD stock, and I'm wondering if I should start saving up for a new dif...
I have a GTM stage 2 kit and just dyno'd at 515/510. How many people have grenaded their stock dif?
Old Jul 26, 2010 | 01:47 PM
str8dum1's Avatar
str8dum1
SP uses stock rear end at 1250whp. YOu have a long way to go before you have to worry about blowing it up. Now getting one for better traction is a reasonable goal.
Old Jul 26, 2010 | 02:53 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Stock one here with 688ft/lbs @ high boost.
Ive driven Carbonetics diffs and didnt think it was as much of a diff as its made out to be, in other words I wasnt impressed.
Old Jul 26, 2010 | 03:42 PM
thom000001's Avatar
thom000001
stock vlsd here...and just made 801rwhp (don't know tq yet...didn't have tach reading).
The rear mounting bolt on the cover is the weak point not the diff itself.
Tom
Old Jul 26, 2010 | 07:34 PM
ffwturboZ's Avatar
ffwturboZ
How do I know if I have a VLSD? I just picked up an 03 Track.
Old Jul 26, 2010 | 07:53 PM
konrad's Avatar
konrad
I know 240 guys are opening the diffs and adding an additional shim between the sides, that makes it 1.5 way lock , and they get better traction, not too sure about how long it will last you , i'm about to get on this project myself
Old Jul 27, 2010 | 05:17 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Every model other than the base has an LSD
The fun way to get the answer would be a redline clutch dump and observe the tracks!
Old Jul 27, 2010 | 06:23 AM
thom000001's Avatar
thom000001
Wating for thread on broken Axles......
Tom
Old Jul 27, 2010 | 06:51 AM
str8dum1's Avatar
str8dum1
or if you jacked the rear up and spun the tires. they should go opposite direction if you have a lsd.
redline dump is probably more accurate though
Old Jul 27, 2010 | 08:31 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
My 6speed street car went low 9's on the stock LSD. Our auto drag car made many 8 second passes on stock dif without fail. I wouldn't worry too much about the dif
I would suggest using an IP dif brace if you plan on racing or use an aggressive-engaging clutch.
Old Jul 27, 2010 | 08:38 AM
midz350's Avatar
midz350
My dif makes an awful sound and kick when changing gears driving hard
More stuff to buy
Old Jul 27, 2010 | 08:45 AM
bldg250z's Avatar
bldg250z
is there a weak point in the rear end that we would need to worry about when dragging the car..... in other words do i have to worry about running my two step on slicks and dumping the clutch at about 7 psi..... what are necessary upgrades to not have it snap something .... not to knowledgeable on the rear end!
Old Jul 27, 2010 | 08:50 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Worry about slicks? I wouldnt enough to not run them. When racing you WILL eventually break $hit, its a reality you have to accept.
I can tell you however if you DUMP the clutch as opposed to preloading and doing a quick slip or launching your chances of breaking are significantly higher.
Old Jul 27, 2010 | 08:53 AM
Dynosty's Avatar
Dynosty
The dif should be fine with the above-noted brace, as should the stock driveshaft. The axles on the other hand, definitely need to be upgraded. I would suggest DSS Pro axles. These are a little more expensive than DSS Stage 5 axles, but come assembled with upgraded ends, whereas the Stage 5's require swapping your stock inner hubs onto the DSS Stg5 axles.
DSS Pro:
DSS Stage 5:
Old Jul 27, 2010 | 08:54 AM
Dynosty's Avatar
Dynosty
+1 , I agree.
Old Jul 27, 2010 | 08:55 AM
thom000001's Avatar
thom000001
the diff gears are fine...the mounting isn't great...look at the diff braces (IP and SP both offer them).
Next would be the CV joints and Halfshafts.
Tom
EDIT- Darnit' Hal...beat me on the clicks lol
Old Jul 27, 2010 | 09:07 AM
str8dum1's Avatar
str8dum1
also running slicks is WAAY easier on the car then DR's
Funny because in the Supra forums, they are adamantly against DR's on 6speed cars, but here DRs are the norm.
Old Jul 27, 2010 | 09:28 AM
thom000001's Avatar
thom000001
They do tend to have a bigger "hit" of power in the big singles that makes it hard for the tires to handle....we have a little more tq to help make things a little more linear. I'm sure everyone here will eventually learn that slicks are the only way to lay power down eventually.
Tom
Old Jul 27, 2010 | 10:46 AM
seymore4's Avatar
seymore4
Professional
Thanks for all the input! I have a lot of friends that drift and are always destroying stuff.. lol makes a guy wonder
Old Jul 27, 2010 | 12:01 PM
bldg250z's Avatar
bldg250z
I completely agree with breaking sh*t, it will happen and makes sense not to dump it completely.... I know launching hard will have its wear and tear. thanks
DSS Pro:
DSS Stage 5:
Tom
thanks for the info i will look into buying this after the build is done ....
sorry OP i took the opportunity to ask....
