cheap gauge alternative (water/intake temp)
Old Aug 27, 2010 | 02:32 PM
  #41
Vas_Z33's Avatar
Vas_Z33
Originally Posted by zmedic16
+10000000
looks good man! for 40$ , good deal. Does it read oil temp? ( I forget )
Old Aug 27, 2010 | 02:49 PM
  #42
zmedic16's Avatar
zmedic16
Wish it did.
Old Aug 27, 2010 | 08:41 PM
  #43
JDMStanced's Avatar
JDMStanced
So what are the features that WORK for 350z?
Old Aug 28, 2010 | 04:44 PM
  #44
cdoxp800's Avatar
cdoxp800
Here is what it picked up on my 06 Mt.
Vehicle #1
<table border="0" cellspacing="1" width=""> <tbody><tr> <td> Manufacture Date:</td> <td> 08/2006</td> </tr> <tr> <td> Transmission:</td> <td> Manual</td> </tr> <tr> <td> Protocol:</td> <td> 9141</td> </tr> </tbody></table>
  • Open/Closed Loop Emissions Status
  • Percent Engine Load
  • Engine coolant temperature
  • Short Term Fuel Trim Bank 1
  • Long Term Fuel Trim Bank 1
  • Short Term Fuel Trim Bank 2
  • Long Term Fuel Trim Bank 2
  • RPM
  • MPH
  • Ignition Timing Advance
  • Instake Air Temperature
  • Mass Air Flow Sensor output in grams/sec
  • Absolute Throttle Position Percentage
  • Bank 1 Oxygen Sensor 1 Voltage
  • Bank 1 Oxygen Sensor 2 Voltage
  • Bank 2 Oxygen Sensor 1 Voltage
  • Bank 2 Oxygen Sensor 2 Voltage
  • Distance traveled with Check Engine Light on
  • Mass Air Flow 2, Calibrated/Calculated
  • Instantaneous Miles Per Gallon (MPG)
  • Average Miles Per Gallon (MPG)
  • Average Miles Per Hour (MPH)
  • Average Gallon Per Hour (GPH) - general
  • Run Time - general
  • Distance - general
  • Fuel Used - general
  • Intantaneous Gallons Per Hour (GPH)
  • Fuel Tank Gallons Remaining
  • Distance to Empty(DTE)
  • Time to Empty (TTE)
  • Volumetric Efficiency (MAP vehicles only)
  • Average MPH - trip
  • Average MPG - trip
  • Fuel Used Gallons- trip
  • Average Gallon Per Hour (GPH) - trip
  • Run Time -trip
  • Distance - trip
  • Oil Distance
  • Service Distance
  • UltraGauge Temperature
Old Aug 29, 2010 | 07:19 AM
  #45
graffkid732's Avatar
graffkid732
Just used it yesterday to clear a code. Worked great. Fast and no problems at all.
Old Aug 29, 2010 | 03:17 PM
  #46
Sylvan Lake V35's Avatar
Sylvan Lake V35
I see it is still on sale, I was hoping it wouldn't be I am temped to get one just for coolant temp and IAT.
Old Aug 29, 2010 | 04:22 PM
  #47
djamps's Avatar
djamps
Seems really cool I just don't like the idea of something hanging off the ODBII port constantly..anyone thought of hardwiring (with quick disconnect) or adding a 2nd ODBII port or something?
Old Aug 29, 2010 | 04:34 PM
  #48
0jiggy0's Avatar
0jiggy0
I got mine. Its definitely cheaply made. Its cool with what it does. Im working on a hyundai with a TPS problem and it showed me the TPS percentage while using the throttle.
Old Aug 29, 2010 | 10:13 PM
  #49
Vas_Z33's Avatar
Vas_Z33
yeah it feels cheaply made but it does the job....
HOWEVER..
I was having some problems with mine today.. I did read somewhere on there forums that some people were having problems with draining the battery... and something similar to that happened to me today.. about 30 min ago, at 1am.. the worst night of my life... all of a sudden my car just turns off in the middle of driving.. I dont want to give any more details out.. I have to do more testing tomorrow to find out that if the ULTRAGAUGE caused the problem or not.
Ill update soon.
Old Aug 29, 2010 | 10:42 PM
  #50
accordfreak's Avatar
accordfreak
i actually had an issue with my tach not working with the UG which kinda put my car in limp.. They said I had to force the 9141 protocol. There's a option on the main menu to force the protocol.
Old Aug 29, 2010 | 11:19 PM
  #51
2004Black350z's Avatar
2004Black350z
Exhaust Whore
yikes at the probs already. Maybe a cool device to have plugged in 4 a few mins but not constantly on
Old Aug 30, 2010 | 07:58 AM
  #52
Vas_Z33's Avatar
Vas_Z33
yesterday I did notice.. my tach needle ( RPM ) was very very bouncy.. like it would drop and spike!.. NEVER done that before... and it threw the ABS,break and slip light on.. I have to do more research about it. Im going to get my alternator checked today and drive my car without the UG being connected.
Old Aug 30, 2010 | 08:33 AM
  #53
MDHRZ's Avatar
MDHRZ
Does feel very cheap. Glad I didn't connect mine yet! Might send it back now...
Old Aug 30, 2010 | 09:24 AM
  #54
accordfreak
try to force the 9141 protocol on the gauge. It's on the main menu "force protocol"
I didn't have a problem after I forced it.
Old Aug 30, 2010 | 09:41 AM
  #55
accordfreak
I was diggin around the website and found a knowledge base item on it
http://ultra-gauge.com/customer_supp...icle=6&rated=1
Old Aug 30, 2010 | 10:13 AM
  #56
zmedic16's Avatar
zmedic16
simple as force protocol, no probs.
Old Aug 31, 2010 | 02:09 AM
  #57
0jiggy0's Avatar
0jiggy0
I found out on the hyundai I was working on the TPS percentage wasnt reading properly. The TPS was the problem but when I put it in the car the gauge didnt read right. So i'm thinking "****" its something else. Well the check engine light didnt come back on and the car was driving 10 times better. On the gauge the TPS never moved from 1 percent. The IAT and coolant temp seemed to be reading properly though...
I still like it for what it is and I'm getting used to it. It will help me with backyard fixes.
Old Aug 31, 2010 | 10:48 PM
  #58
KingBaby's Avatar
KingBaby
Hardest Setting
just got one...
mounted it on the left side of the steering wheel, where it displays right next to the tripod guages kinda stealthy where I got it...
I'll post a pic
works fine
nice to have something else to look at when driving...
Old Sep 1, 2010 | 12:01 AM
  #59
djtimodj's Avatar
djtimodj
I hope the gauge does not cause problems as I've got one coming over to me in the UK. I need it to check my coolant temps due to the over heating probs I've been having. Im looking to mount it in the cubby or make a custom pod and dash mount it.
King baby post pic's of where you have yours?
Also Vas what year is you zed dude? My cars MY03 so i hope it dont have and probs with the Gauge/ecu!
Old Sep 1, 2010 | 04:18 AM
  #60
Vas_Z33's Avatar
Vas_Z33
mines 03. I did do a lot of testing yesterday.. I got the alternator checked ( thinking it was the problem that caused my car to shut off.. ) but that passed with flying colors..
I plugged the UG back up and I did force protocol.. and its been perfect since yesterday.. no needle jumping, no weird slip light...
Id highly recommend everyone doing this..
