What was your DynoJet elevation reading?
Old Aug 22, 2010 | 04:24 AM
maXmood's Avatar
maXmood
Under Boost!
Default What was your DynoJet elevation reading?
Even tho i'm producing low numbers on my car (304whp on DynoJet, my SC setup https://my350z.com/forum/forced-indu...-sc-setup.html), and i'm at sea level, i was wondering what was the dyno elevation parameters set on when you dyno'ed yours?
where i am, DynoJet is set to 4500 elevation.. don't ask me why, because i'm trying to figure out if i should compare my gains with everyone else.
Ppl with 5AT Vortech SC kit + 2.87" pulley on a stock block, can you please chim in with this kind of details?
TA
Old Aug 22, 2010 | 05:43 AM
binder's Avatar
binder
all the parameters on a dyno should be set according to current conditions.
altitude, humidity, temperature, etc
Old Aug 22, 2010 | 05:59 AM
GT-ER's Avatar
GT-ER
I can't find elevation. I have most of the dyno runs in my computer and I have the winpep software. I see humidity, temp and baro. pressure....but no elevation.
Old Aug 22, 2010 | 06:19 AM
maXmood's Avatar
maXmood
Under Boost!
problem is, i don't think it's set correctly on the dyno. that's why i'm looking for someone with the similar setup to see if i can compare power output we got.
i think it's only set on the dyno winpep software.
when you get the time (even tho i don't think you're on a DJ), ask your dyno/tuner about the elevation numbers.
Old Aug 22, 2010 | 06:32 AM
Erdem's Avatar
Erdem
did u ever try another dyno?
Old Aug 22, 2010 | 06:35 AM
maXmood's Avatar
maXmood
Under Boost!
^tbh, i've done both base and sc setup dynos on Dynojet, but in two different shops.
Old Aug 22, 2010 | 06:40 AM
GT-ER's Avatar
GT-ER
I use a DJ. Winpep is the software DJ's use. How did you see elevation?
Old Aug 22, 2010 | 06:42 AM
GT-ER's Avatar
GT-ER
Found it...mine says 4500ft which is not true since it's near sea level where the dyno is. I guess 4500 is the default?
Old Aug 22, 2010 | 06:51 AM
ashtrojan2008's Avatar
ashtrojan2008
I just checked my dynojet run, elevation was set to 180ft in Houston. Not sure how far that 4500 will throw things off but it's definitely not correct.
ross
Old Aug 22, 2010 | 06:53 AM
maXmood's Avatar
maXmood
Under Boost!
i asked for it...
looks like 4500ft is the default. but it shouldn't be that.
so if we compare your setup to mine when you had the stock intercooler, it all pours into the tune + weather.
Old Aug 22, 2010 | 07:02 AM
maXmood's Avatar
maXmood
Under Boost!
ross
what's your setup? what are your numbers?
4500ft to 180ft will push those numbers up high.
Old Aug 22, 2010 | 07:22 AM
GT-ER's Avatar
GT-ER
i asked for it...
I would think so...more tune than anything else since the weather should not affect much at all due to the correction factors ( Whether they are SAE or STD or whatever ).
Old Aug 22, 2010 | 07:30 AM
ashtrojan2008
this was a loooong time ago but street tuned utec greddy tt 14psi
482whp 450 ft lbs torque
i'm getting tuned at injected, which lexington ky is around 1000ft and i live basically at sea level. I wonder if it'll make much of a difference.
ross
Old Aug 22, 2010 | 07:46 AM
zaperroni's Avatar
zaperroni
since when was 4500 feet sea level?
Old Aug 22, 2010 | 08:38 AM
GT-ER's Avatar
GT-ER
You guys aren't getting it. He's at sea level, just like I am. The dyno however says 4500ft which is wrong. He's wondering how this would affect hp readings.
Old Aug 22, 2010 | 11:49 AM
tylerxfire's Avatar
tylerxfire
get on another dyno...ill check mine later if i can find it but couldnt find it last time i looked...ur power is waaaaaayyy low if that is all correct
Old Aug 22, 2010 | 12:10 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Wouldn't your numbers be higher because the dyno thinks it is at 4500ft and would correct the altitude sea level. Depending on how the dyno is set up. I know I am at 5000ft DA then the dyno corrects it to sea level but if your already at sea level and the dyno thinks your at 4500ft then corrects it wouldn't that make the number higher.
It would depend on how the correction factors are set up on the dyno.
Old Aug 22, 2010 | 01:23 PM
maXmood's Avatar
maXmood
Under Boost!
^ exactly!
e.g. a car dyno'ed 300whp on 450ft elevation, what's it gonna be on 4500ft elevation?
i'm thinking of doing another run on the previous DJ.
post your info when you find it.
thanks
i think it's the other way around... i'm getting confused!
Old Aug 22, 2010 | 02:25 PM
binder's Avatar
binder
ross
hey, your profile says LA instead of IA. FYI
where do you live in IA that is at sea level? I'm in st louis for school and i'm right on the mississippi and we are still at about 500ft elevation. I figured all around the miss river it was about 500ft elevation.
and it won't effect it. That's why we tune to VE. It makes adjustments to the car. I didn't have a single problem from Lexington to st louis or my hometown in indiana which is 650ft.
Old Aug 22, 2010 | 02:33 PM
GT-ER's Avatar
GT-ER
I actually thought the same thing...
