What was your DynoJet elevation reading?
Old Aug 23, 2010 | 05:55 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
[QUOTE=maXmood;8608775
i think it's the other way around... i'm getting confused![/QUOTE]
At 5000ft my old set up did 380whp and corrected to sea level was 400whp. So if your dyno thinks it is at 4500ft when it corrects it to sea level it will add aprox 20whp?? I could be wrong.
Old Aug 23, 2010 | 07:17 AM
maXmood's Avatar
maXmood
Under Boost!
if that's the case, then i can at least get a good comparison..
ppl over the forum with a similar setup to mine are producing 380-400whp on DJ, while i'm @ 304whp only.
keep in mind we got crappy fuel, and crappy weather all year long.
just trying to figure out what's wrong.
Old Aug 23, 2010 | 09:07 PM
midz350's Avatar
midz350
Just take it to Bahrain international circuit and see what will do in the 1/4 mile.
Old Aug 23, 2010 | 09:53 PM
maXmood's Avatar
maXmood
Under Boost!
i need to look into that.. because i don't know what should be my record as. high 12s?
Old Aug 23, 2010 | 10:14 PM
midz350's Avatar
midz350
It depends on your driving skills.
Old Aug 23, 2010 | 11:41 PM
maXmood's Avatar
maXmood
Under Boost!
^my car is 5AT.. i don't think it requires much skills
Old Aug 23, 2010 | 11:53 PM
midz350's Avatar
midz350
I think with a good launch and 304whp mid to low 12s.
Old Aug 24, 2010 | 04:40 AM
GT-ER's Avatar
GT-ER
I think with a good lunch and 304whp mid to low 12s.
Mid to low 12's on stock weight? I say low 13's to high 12's.
Old Aug 24, 2010 | 05:10 AM
rcdash's Avatar
rcdash
It does to launch without throttle cut, bogging or spinning. You have to perform some kind of mod (e.g. cut the wire 101 to the ECU) to brake torque launch.
I believe Sylvan Lake is correct in regards to the elevation correction. If Dynojet is set to correct for 4500 ft, then it will falsely elevate the hp.
Old Aug 24, 2010 | 06:58 AM
marra23's Avatar
marra23
Interesting, we're at 4500-5000ft and 300-320whp is what the votech guys pull around here with out corrections.
Old Aug 24, 2010 | 08:03 AM
maXmood's Avatar
maXmood
Under Boost!
with 2.87" pulley and full breather system?
Old Aug 24, 2010 | 09:58 AM
midz350's Avatar
midz350
Stock 350z HR and 370z doing low 13's to high 12's with (270-280whp)
Old Aug 24, 2010 | 10:09 AM
ITOzann's Avatar
ITOzann
have you tried a different dyno? I had an issue like yours with my tuner's low calibrated mustang dyno.
Old Aug 24, 2010 | 02:26 PM
maXmood's Avatar
maXmood
Under Boost!
^i haven't, but i have this in mind. even tho i'm sure it shouldn't change alot, but i'll give it a shot.
Old Aug 24, 2010 | 03:17 PM
ITOzann's Avatar
ITOzann
Give it a shot. In my case, I spent the extra 80 bucks and went to a different dyno (DJ) since I was scared of my low gains(50-70whp difference). The number I got on the DJ turned out to be about the same as what other guys have with my same sc. Give it a try..
Old Aug 24, 2010 | 11:16 PM
maXmood's Avatar
maXmood
Under Boost!
^same elevation?
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
