Stillen Stage 2 Supercharger vs Turbonetics Single Turbo Kit
Old Sep 10, 2010 | 11:22 PM
  #121
zmedic16's Avatar
zmedic16
i might be talking out of my **** here but the vq38 out of the gtr is just close deck motor. i dont recall anything about sleeves. oh and salute to the soldier. word of advice around here is to read a ton.... thats most of what i do around here.
Old Sep 11, 2010 | 06:38 AM
  #122
roger22's Avatar
roger22
Originally Posted by ADMAN
A: They haven't "eaten belts" in a very long time.
Yes, they do, I had the 6 rib belt and they still eat them on the track...POS design...
Old Sep 11, 2010 | 07:46 AM
  #123
BoostedTreeFity's Avatar
BoostedTreeFity
Originally Posted by 2004Black350z
Can't start over bro. Your ignorant. Don't come to a site like a know it all when in fact all u know is nada.
***** I NEVER CAME ON HERE LIKE I KNOW IT ALL YOU *********** ARE THE ONES WHO APPARENTLY KNOW EVERY GOD DAMN THING UNDER THE PLANET ABOUT EVERY ENGINE EVER MADE AND APPARENTLY ALSO KNOW WHAT I HAVE AND HAVENT DONE IN MY LIFE, GO **** YOURSELVES ALL YOU POMPUS IGNORANT AROGENT PIECES OF BOTTOM FEEDING ****. There I'm done...**** your mother
Old Sep 11, 2010 | 08:16 AM
  #124
Vas_Z33's Avatar
Vas_Z33
damn what the hell is happening here..
Old Sep 11, 2010 | 08:23 AM
  #125
go-fast's Avatar
go-fast
Attached Thumbnails Stillen Stage 2 Supercharger vs Turbonetics Single Turbo Kit-1216210091938.jpg
Old Sep 11, 2010 | 09:02 AM
  #126
doug's Avatar
doug
Old Sep 11, 2010 | 09:26 AM
  #127
ReV2Red's Avatar
ReV2Red
I haz da turbos
Soldiers on roids these days?
Dayum!
Old Sep 11, 2010 | 09:29 AM
  #128
ReV2Red's Avatar
ReV2Red
I haz da turbos
a) don't sleeve the motor unless your going for real big power
b) don't go as low as 7.5 compression, the car will drive like **** off boost
c) lay off the drugs, or get laid. or both.
Old Sep 11, 2010 | 09:44 AM
  #129
Vas_Z33's Avatar
Vas_Z33
Old Sep 11, 2010 | 09:50 AM
  #130
BoostedTreeFity
a) Shut your mouth no one was talking to you
b) Cut back on the wacking
c) Pull your finger out of your *** and go do something with yourself
Old Sep 11, 2010 | 10:08 AM
  #131
zmedic16's Avatar
zmedic16
this is what you called flamed.
Old Sep 11, 2010 | 10:24 AM
  #132
Sylvan Lake V35's Avatar
Sylvan Lake V35
Ok this is getting WAAAAAAAY out of hand. Lets start this over shall we? Hello my name is Joe, I am a soldier stationed on Ft Drum, I have been building performance cars since I was 18(sigh 10 years) and have recently gotten a boosted 350Z and am looking to A) Do a nice rebuilt low compression motor. B) Raise my boost a bit. C) Enjoy the car for years to come.
IslandZavage; Thank you for the info, I was unaware the VQ's dont like being sleeved, I've sleeved almost every engine I have rebuild with outstanding power, efficiency, and reliability/durability results. Many of the worlds top performing cars are sleeved from the factory and when race prepped(C5/C6R *drool)
And isnt the VQ38 sleeved? I think I remember comming across a thread on here about it
Lots of us had horrible experience with sleeved engines, they just don't seem to go well with the VQ and head lift seems to happen more often than not. No one really even runs sleeves on road race or street cars anymore due to the stock sleeve engines being able to hold 800whp.
I was going to "O" ring my sleeved engine after it failed but I just gave up on in and now I am just building a stock bore 3.5L hopefully that goes better for me.
Old Sep 11, 2010 | 10:26 AM
  #133
BoostedTreeFity
[QUOTE=Sylvan Lake V35;8651067]Lots of us had horrible experience with sleeved engines, they just don't seem to go well with the VQ and head lift seems to happen more often than not. No one really even runs sleeves on road race or street cars anymore due to the stock sleeve engines being able to hold 800whp.[/QUOTE
Hmmmm interesting, I wonder why the VQ doesnt like being sleeved. And if your running a stock sleeved engine then your still running an engine that has been sleeved.
Old Sep 11, 2010 | 10:31 AM
  #134
BoostedTreeFity
Originally Posted by go-fast
This quote says your "halfway through a complete rebuild" and that makes you a liar if now your saying the machine shop is awaiting your "word".I didn't bash you for your obvious lack of automotive knowledge,but when you contradict yourself and no one points it out it's time for me to post.
i'm sure your more than able to have someone sleeve your motor.....gl with that.
http://www.*********.com/forums/119-...de-blocks.html
Old Sep 11, 2010 | 10:34 AM
  #135
BoostedTreeFity
I wouldnt suggest fire rings unless your using a cast iron block, thats a trick we use in the Turbo Diesel community when we exceed 50psi
Old Sep 11, 2010 | 10:36 AM
  #136
Sylvan Lake V35
Any engine that is aluminum will have some sort of steel sleeve/liner as far as I know. Then engine I am building will have OEM cylinder bores, to be clear the majority of aftermarket sleeved engines seem to have issues however the OEM blocks bored .020 over don't seem to have issues some have even held 800whp. Some of the big power drag cars do seem to use aftermarket sleeved blocks with no issues.
As far as I know there is not a HG with fire rings availible for big bore (100mm) VQs, I did however try a Cometic Phuzion gasket that has an expanding gas filled ring. The OEM HR head gaskets (95.5-96mm) do have a fire ring so they are becoming fairly common in builds now.
Old Sep 11, 2010 | 10:44 AM
  #137
BoostedTreeFity
Cool so you should know the head has to have the chambers machined to accept the ring then right? I have actually seen some "built" motors come in that were pushing upwords of 30psi and wondered why it failed, once the heads came off they stuck the rings in and used them like a crush washer which is not the correct way to use a fire ring kit, there has to be a groove machined into the chambers for the ring to seat into
Old Sep 11, 2010 | 12:27 PM
  #138
BoostedTreeFity
Sylvan may I ask what you are using for studs?
Old Sep 11, 2010 | 12:33 PM
  #139
ReV2Red's Avatar
ReV2Red
I haz da turbos
oooooooooo.....touchy
a) and b) where actually honest comments...................................so was c)
Old Sep 11, 2010 | 02:33 PM
  #140
BoostedTreeFity
K whatever I'm not gonna bash on you anymore because I love Family Guy, Quagmire is the ****, and I say Giggiddy all the time. Nice ride btw what track were you at?
