RC Injector Clips
Old Sep 10, 2010 | 09:25 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default RC Injector Clips
Does anyone know which one to we need to order that don't involve cutting and soldering like the type C.
The only other ones they have are the Bosch, Honda,or Denso clips.
It's for a set of 650cc RC injectors.
Basically i want something plug and play. Is that possible?
Old Sep 10, 2010 | 03:02 PM
MDK's Avatar
MDK
You can buy these premade from RC for around $60. I've got them on my car, they were purchased from THMotorsports.
Old Sep 10, 2010 | 11:01 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yes, i know you can get them. What i need to know is wether i need the Bosch style or the Denso style when going from OEM injectors to RC650cc injectors.
Old Sep 11, 2010 | 03:52 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I believe they are bosch style.
I have the injectors from an aps kit (presumably bosch) and I have the aps harness. The harness I have fit my buddies RC injectors. He kinda wants the harness too since it is much cleaner than splicing.
Old Sep 11, 2010 | 04:11 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Are your certain their the Bosch style? Can anyone confirm?
Thanks for the help Cux!
Old Sep 11, 2010 | 12:30 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Yeah pretty sure they are Bosch.
Old Sep 13, 2010 | 04:52 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
So all the pro shops and tuners on this site, and nobody has installed an injector clip?
Thanks for your help Cux. I'm sure your right, i just need to have a confirmation before i buy them.
Anyone?
Old Sep 13, 2010 | 07:54 AM
str8dum1's Avatar
str8dum1
oem is denso, rc is bosch EV1
Old Sep 13, 2010 | 08:02 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
part of the reason why i went with DW injectors was to avoid splicing ect with the RC injectors.
RC's are cheaper in the beginning but the extra work is not worth it imo. I got my DW for a great price and they are drop ins.
Old Sep 13, 2010 | 09:51 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Ok. In which case it's impossible to get either of these no?
Or do you mean i would need the Denso one, as the Bosch side is already there anyway for the RC injector?
Old Sep 13, 2010 | 10:11 AM
str8dum1's Avatar
str8dum1
if yo udont want to solder you must get the denso to EV1 adpators like these http://cgi.ebay.com/ebaymotors/ws/eB...m=370421311769
if you are going to cut and solder you need to just get the EV1 clips with just wires like these http://cgi.ebay.com/ebaymotors/ws/eB...m=320405570568
I just soldered on the EV1 clips so I can hotswap both kind of injectors
Old Sep 13, 2010 | 10:18 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
So i would have to get these then if i want plug and play
http://www.rceng.com/Denso-Clip-Connector-P48C9.aspx
Old Sep 13, 2010 | 10:53 AM
str8dum1's Avatar
str8dum1
yes, exactly
Old Sep 13, 2010 | 10:56 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
cool, thanks.
Old Sep 13, 2010 | 01:23 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Right so spoke to my tuner and he says they won't fit the Z. I sent him the link and he says they wont fit.
Old Sep 13, 2010 | 02:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
is he referring to having to use larger fuel rail spacers?
I know the cosworth plenum requires a spacer with some of the taller injectors...I believe RC falls into that category.
Old Sep 13, 2010 | 03:29 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I'm not sure, but *** it, i'm going to get the denso style adapters and if they fit then great, if not, i can still cut them and splice them.
Old Sep 15, 2010 | 07:33 AM
350z006's Avatar
350z006
They will work, trust me I'm using the denso adapters on my setup with RC injectors...I don't know what your tuner is talking about...
However, you may have to grind your fuel rails a bit since it may touch your lower plenum with the taller RC's, and you will need taller injector spacers as well; if you bought the RC's new specifically for 350z's it should have come with the taller spacers, if not you can buy them from RC...
Old Sep 16, 2010 | 12:06 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I got the injectors with Ddub's HKS kit that he was selling, so i would assume it come with it all. I'll have to check and make sure.
Thanks for the help!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
