spark plug gap???
Old Sep 15, 2010 | 08:49 AM
travismaser's Avatar
travismaser
Default spark plug gap???
what would you guys recommend for gap on a set of 2 step colder plugs for my z??
would it be different then the stock?
Old Sep 15, 2010 | 09:06 AM
thatv35guy's Avatar
thatv35guy
Not sure…but with my car I went with one step colder and didn’t adjust the gap, I just went with what NGK had them set at. Kind of wondering now, did anyone adjust the gap from the setting they come with?
Old Sep 15, 2010 | 09:21 AM
DavesZ#3's Avatar
DavesZ#3
Hot/cold plugs are different models than OEM. The gap is preset at the factory and they are all the same.
Old Sep 15, 2010 | 10:34 AM
str8dum1's Avatar
str8dum1
considering the only NGK that is 2 step colder is an iridium plug, you do not touch the gap.
Old Sep 15, 2010 | 10:37 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
How much power are you making? If it is not blowing out or having a misfire problem under boost, don't lower the gap. If it is, and you are using iridium, it is possible to make the gap smaller but you must take care in doing so. Also if you are having a spark blowout problem, make sure you are taking advantage of max dwell if you have an EMS that allows for dwell control.
Old Sep 15, 2010 | 10:41 AM
travismaser
thanks alot guys...i called GTM and spoke with Sam...he let me know that they were preset gaps...i guess we learn something new everyday haha
Thanks Hal@IP...im running right over 400 wheel right now but plan on going with more...so that info could deff be usefull in time!
Old Sep 15, 2010 | 10:46 AM
str8dum1's Avatar
str8dum1
how would one distinguish the need to increase dwell compared to reducing the gap? and
how does one tell if the dwell should be continued to be increased (ie maximim before you burn out your controller)
Old Sep 15, 2010 | 11:31 AM
thom000001's Avatar
thom000001
BTW - you do not need 2 step colder plugs at that power.
Tom
Old Sep 15, 2010 | 12:20 PM
Dynosty's Avatar
Dynosty
travis, no prob. Glad they got you taken care of. I agree with thom, in that you would be safe with 1step colder for 400whp.
str8dum1, increase dwell first to safe maximum. If spark breakup persists under maximum load and ignition system is known good - reduce gap. As for maximum dwell... testing. We have done it and provide this to our customers.
Old Sep 15, 2010 | 04:30 PM
str8dum1's Avatar
str8dum1
ok, thats what I thought that Haltech was already set
Old Sep 16, 2010 | 10:41 AM
travismaser
yea, i had one step colder but i decided to try it out with 2 steps....it seems to run a little better? but im sure thats my a$$ dyno talking haha
Old Apr 12, 2011 | 11:08 AM
J-P-T's Avatar
J-P-T
Question
Hey guys,
I've searched, but didn't see this question definitively answered. With a turbonetics Turbo kit (60-1 turbo), stock compression motor (2003 350z 6spd), 10psi boost, can I get away with a stock gapped spark plug that is just 1 heat range colder? Also, what do you guys recommend as the best plug for this setup? (trying to avoid manually re-gapping plugs) Thanks!
Old Apr 12, 2011 | 11:37 AM
DaveJackson's Avatar
DaveJackson
Master
Searched??? Don't posts 5 and 9 from Hal answer the majority of your question?
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
