Turbonetics install picture with Oil cooler.
Old Sep 24, 2010 | 04:15 AM
travismaser's Avatar
travismaser
great numbers! i like it!
Old Sep 24, 2010 | 05:00 PM
twitch579's Avatar
twitch579
Could not take the car home to make in car videos. There having problems bleeding the clutch. The fluid wont pull thru.
Tomorrows another day I guess.
Old Sep 24, 2010 | 08:00 PM
djamps's Avatar
djamps
Sounds like a healthy tune (on the first pull at least!)
Old Sep 25, 2010 | 05:08 AM
twitch579's Avatar
twitch579
Yes Martain at Z-Fever is doing the tune, hes very good at what he does and is actually doing all the tunes now for Threadstone. The car pulls smooth as butter.
Were having the typical boost creep issues that plagues the Turbonetics kits. The boost will go from 9 to 10lbs in every gear. At night when its cooler I actually seen 11lbs on the gauge...pretty scary on a stock bottom end.
Old Sep 26, 2010 | 02:44 PM
twitch579's Avatar
twitch579
Car is smoking when I let of the trottle after fully boosting. Doesnt do it though when on the gas, just when u lett off after boost. Will shoot out a not so bad cloud or white smoke with possibly a blue tint, its hard to tell.
Is that a sign that I need a catch can?
Old Sep 26, 2010 | 03:20 PM
RA11325's Avatar
RA11325
Looks good.
Old Sep 26, 2010 | 04:11 PM
twitch579's Avatar
twitch579
Gonna try this. Searched for hours to find this thread. https://my350z.com/forum/forced-indu...m-exhaust.html
Old Mar 27, 2011 | 09:31 AM
twitch579's Avatar
twitch579
UPDATE TO OLD THREAD!
ENGINE THREW A ROD TODAY AFTER 16,400 MILES OF HARD BOOSTING AT 10LBS.
Motor had 66k miles when kit was installed. No plans as of yet for rebuild...I really want a Vette now.
Old Mar 27, 2011 | 09:37 AM
djamps's Avatar
djamps
Yet another TN kit having rods for lunch...good luck with your future plans, be sure to research well.
Old Mar 27, 2011 | 09:44 AM
suprasam's Avatar
suprasam
Sucks bro! Good luck on your future plans.
Old Mar 27, 2011 | 09:55 AM
graffkid732's Avatar
graffkid732
Damn, sorry to hear. Good luck with what ever you decide to do.
Old Mar 27, 2011 | 10:05 AM
jeffie7's Avatar
jeffie7
I thought this was going to be a DIY on how to remove a TN kit.
People still install them?
*scratches head* I just can't figure it out.
Old Mar 27, 2011 | 10:10 AM
twitch579's Avatar
twitch579
The car was a total blast to drive, it pulled really really hard! I actually didnt expect it to last that long at all, the motor was on Nitrous from the day it was installed..ususally 2 bottles per weekend. I never expected it to last even this long.
Im thinking a new and less abused long block would have lasted twice as long..Im actually debating just swapping out another longblock perhaps a Revup oil burner that I can find on CG. I might even run 11lbs on this block.
Building a shortblock for a TN kit is like a pissing in the wind lol. The car itself has over 150,000 miles on it and I dont plan on spending alot of money on it to get it running again.
This actually threw a rod in my plan of supecharging my Titan Truck this summer lol!!!
Old Mar 27, 2011 | 10:21 AM
djamps's Avatar
djamps
An OC block will most likely fail sooner/harder -- oil mixed in with the combustion reduces octane and will cause some hardcore detonation under boost. If you were running meth and/or dialed back your timing at peak tq you probably would have gotten some more miles from your last block. (assuming a failure on the TN kit didn't actually cause the meltdown, massive boost spike for example which is not uncommon with these)
Old Mar 27, 2011 | 11:15 AM
twitch579's Avatar
twitch579
Yes, I totally agree, but spending 5k+ on a built shortblock, thats including labor is far more expensive then swapping out a used block for probably $600 plus labor. Also if I can get 30k miles on the next block it will surely be worth it.
Old Mar 27, 2011 | 11:28 AM
SpoilsofWar's Avatar
SpoilsofWar
Only boost spikes I've ever had were when wastegate vacuum lines popped off or rubbed thru due to the close proximity between the wastegate and the radiator - not the best placement by any measure but an easy fix. Its preventable by wrapping that vacuum line with some heatwrap tape or similar. Both times it happened to me my car was on the track, and my UTEC sensed overboost and cut fuel, making a it a non-issue.
Also, converting to an open wastegate dump like I did helps keep the boost steady. The stock TN recirc exhaust piping from the wastegate to the downpipe will crack anyway, eventually
Old Mar 27, 2011 | 11:35 AM
twitch579's Avatar
twitch579
I never got any boost spikes at all, boost was rock solid all the time untill redline. Also I had all the updated piping from Threadstone with the new added Flex Sections to prevent cracked pipes. My AEM truboost has a overboost function too.
Old Mar 27, 2011 | 05:59 PM
  #38
litoflow's Avatar
litoflow
Nice Numbers Twitch!!1 Congrats man. I can't wait for myself to hit the Dyno soon too
Old Mar 27, 2011 | 07:17 PM
  #39
twitch579's Avatar
twitch579
Guess you missed the last few post lol.
Old Mar 27, 2011 | 07:45 PM
  #40
Sylvan Lake V35's Avatar
Sylvan Lake V35
