maybe selling my motor..guaging interest/ opinions
Old Sep 22, 2010 | 02:11 PM
travismaser's Avatar
travismaser
Default maybe selling my motor..guaging interest/ opinions
So I have a rev up vq...its got an APS single turbo setup with a GTM upgrade kit...it has 32,000miles and runs great...made 408WHP and 399TQ...
I am looking at doing a 2jz swap...
What would you guys think I should ask for the motor? I was thinking 5g?? This is with a trans and stage 4 cluch and flywheel
Old Sep 22, 2010 | 02:17 PM
deezz's Avatar
deezz
Sounds like a good deal at 5G.
Old Sep 22, 2010 | 03:17 PM
Velocity350Z's Avatar
Velocity350Z
Why are you doing a 2jz swap? I thought VQ motors are way better than 2jz
Old Sep 22, 2010 | 03:52 PM
twitch579's Avatar
twitch579
2jz > vq
850whp on a stock 2JZ-GTE is a better motor to me.
Old Sep 22, 2010 | 04:31 PM
Velocity350Z
Wow nice, how much does that swap cost?
Old Sep 22, 2010 | 05:02 PM
Glex25's Avatar
Glex25
Sounds like you got a stock motor
or is it a built motor?
If it's built lay out some specs to get a better assesment
Old Sep 22, 2010 | 05:27 PM
zmedic16's Avatar
zmedic16
Originally Posted by twitch579
2jz > vq
you need to take into addition of ems +3k, tune +600$, fuel system +1500$, turbo kit +5-7k, install of the turbo kit if not doing it at the same time of motor swap $$, plus all the other crap it takes a supra 850whp. you make it sound like stock 2jz +boost controller= 850whp. take a look at the mod list of a 850whp supra and guaranteed almost none of them have even stock heads/cams.
Old Sep 22, 2010 | 05:37 PM
Nexx's Avatar
Nexx
damn... reality check.
Old Sep 22, 2010 | 05:38 PM
bigcloud's Avatar
bigcloud
Good stuff zmedic... Also OP you have to consider if your inspections will allow you to swap in an older motor. The 2JZ motor is OBDI if I recall. Most will allow an older motor, but I would check around first. Also why not do a V8? Are you just after numbers? Are you going to track the car? Is this a dyno queen? Most supra's I know with 850whp are either drag cars orrrr dyno queens. Either way should be a "hold on wait" fun type of car.
Old Sep 22, 2010 | 05:43 PM
z2g's Avatar
z2g
not to hijack thread, but I have a built motor that Im about to sell it has approx 8000 miles on it. It was built by importspro. How much should i sell it for?
Old Sep 22, 2010 | 05:53 PM
twitch579's Avatar
twitch579
Most of the guys I know with Supra's are rolling around with 500+ with no other significant mods. Only a few are pushing 700+ and there just tire roasters that cant hook up untill 100Mph+.
Old Sep 22, 2010 | 06:20 PM
travismaser
im aiming for a more dailyable street car with a 6-700 wheel hp rate...my motor isnt built and i know ill have way more money into building it then a 2jz and im deff not going to be able to daily it once id build it...its tough now....
plus i do alot of car shows and a 2jz looks pretty sitting in there :P
do you guys think 5g sounds reasonable?? thats a good running motor with a gt35r and 44mm wastgate, bigger injectors and unichip with transmission (stage 4 competition clutch and 14.5 lb flywheel)
WTFMike's Avatar
WTFMike
Is that $5000 for a stock motor, tranny, and upgraded clutch? Even with those miles that seems kind of high to me. Now, if you were including your turbo setup with the engine,tranny, and upgraded clutch, then that is a good deal.
Old Sep 22, 2010 | 06:24 PM
travismaser
with an aps single turbo setup, gtm upgraded
the aps kit was $5,300 and the upgrade kit was $3,200 alone...plus shop fees...
Old Sep 22, 2010 | 07:13 PM
WTFMike's Avatar
WTFMike
$5000 is a good price for everything with the APS and GTM upgrade.
Old Sep 22, 2010 | 07:22 PM
twitch579's Avatar
twitch579
Yea thats a super deal for an entire boosted powertrain!
Old Sep 23, 2010 | 09:24 AM
str8dum1's Avatar
str8dum1
ya 5k would be good price for a drop in setup. not many people would want a additional stock motor... Good for sentra etc swaps though
big singles are WAY less streetable. its the nature of their power curve. on/off, esp if you want 6-700whp.
you can make 500+ NA with a LS2 swap. doesnt make sense to downgrade your motor both in displacement and headflow just to have a iron block.
A built VQ can make 6-700 just as easily and for less money (unless you are a good welder/fabricator)
This guy spent $21,000 on the swap.
http://www.supraforums.com/forum/sho....php?p=5648218
Old Sep 23, 2010 | 10:01 AM
travismaser
21g is a lil much....with all the parts i should be able to do the swap for under 10...then if i sell my motor...hopefully only about 5....
the 2jz with 6sp trans is only 5g...then the kit (with everything i need) is 2,300...then i figure about 3g in odds and ends...(thats minus the parts i already have)
Old Sep 23, 2010 | 10:04 AM
Nexx's Avatar
Nexx
so youre gonna do all the labor then... then yes it will end up costing about the same as building a VQ.
Old Sep 23, 2010 | 10:35 AM
midz350's Avatar
midz350
Doug.
