NightCrawleR's Project ( phase 1: Engine Build / TT )
Old Jul 4, 2011 | 06:22 PM
  #61
ace32x's Avatar
ace32x
Originally Posted by binder
driver error on gear selection
why do people on this forum want to race at 2800 rpms? just downshift
*also verify there isn't a boost leak but from the sound of it this is normal spool for a gt30 sized turbo setup
isnt he running the gtm stage 2 kit? has the gt28's with the bigger ar if im not mistaken
Old Jul 4, 2011 | 07:14 PM
  #62
nightcrawler_8's Avatar
nightcrawler_8
Yes I have the stg 2 . gt28's
I even push the car From almost 3800 and lag Is there...
What do you guys think of the dyne graph.. Any pointers !?!?
Old Jul 4, 2011 | 07:44 PM
  #63
binder's Avatar
binder
hmm, well that's a bit of an issue then.
The power is there though. You have over 500tq at 4400 rpms which is really good.
maybe look into a boost leak or possible exhaust leak at the manifold or turbo inlet gasket
Old Jul 4, 2011 | 07:49 PM
  #64
nightcrawler_8
I will check that, but I still doubt it's a leak.. As the boost is some how very stable.
I am thinkaybe tuning !!! ( cams tuning to be more specific. )
Maybe my choice of cams was not right !!??
Maybe the intercooler is too big ( I don't know !!!! )
Do you see anything wrong in the graph ??!!
Old Jul 4, 2011 | 08:13 PM
  #65
ace32x's Avatar
ace32x
looks like cam choice to me , i was seeing max spool around 3500 rpm on the same kit on my HR but it was stock block so higher compression, with your cams and the low compression the 4k line seems normal to me
Old Jul 4, 2011 | 10:34 PM
  #66
midz350's Avatar
midz350
The GTM stage 2 kit uses .86 turbine which is kinda big, so you feel the power kick in in the upper RPM. You will notice the car pulls very hard after 5500rpm all the way to 8000rpm.
Old Jul 8, 2011 | 05:23 PM
  #67
IslandZavage's Avatar
IslandZavage
what are your oil temps looking like with it behind the intercooler??? any issues with it like that?
Old May 23, 2012 | 06:52 AM
  #68
nightcrawler_8
update:
Retuned the car on UPREV and damn i love the response.. the response issue was more on the tune..
i got excited and ordered couple of new stuff
- Installed 800cc injectors. ( installed )
- New Spark plugs. ( installed )
- Uprev GT MAF ( on the way )
- Haltech Dual A/F controller ( on the way )
- Custom Gauge that displays two outputs.. will hook it to the haltech to show Bank1 and 2 A/F (on the way)
once the maf arrive we will install and retune the car on 19 psi .. wooot.
The car is
Old Jan 29, 2013 | 06:10 PM
  #69
lp_turbo's Avatar
lp_turbo
any update after 7 months?
I have a similar proget under construction and i'm curious to see new dyno sheet with uprev..
Old May 14, 2013 | 11:35 AM
  #70
nightcrawler_8
Update:
Retuned the car on 16 psi: got 620whp ... Woot
Was not enough, so I installed Crawford intakes and on 16 psi got 690whp (without meth) ... We couldn't continue cause the clutch was slipping...
Was very impressed with the gains from the intake manifold..
All I did was intake and cleaned my filters..
Weather was colder.
Another update,
New look teaser
Old May 14, 2013 | 11:47 AM
  #71
Highway Riding's Avatar
Highway Riding
Man that car looks sexy... Congrats on the new found powa and thx for sharing!
Old May 14, 2013 | 09:31 PM
  #72
nightcrawler_8
Thx...
Old May 15, 2013 | 01:01 AM
  #73
Resmarted's Avatar
Resmarted
You're missing a lug?
Otherwise nice gains and sweet look!
Old Jun 10, 2013 | 09:42 AM
  #74
nightcrawler_8
Updated pics and feature
https://my350z.com/forum/media-share...n-feature.html
350Z_Al
Oct 29, 2020 07:44 PM
