New cylinder block, any machining needed?
Old Oct 7, 2010 | 04:55 AM
scenehouser's Avatar
scenehouser
Default New cylinder block, any machining needed?
Hey guys,
Does a brand new cylinder block need any machining before building it up with a new oem crank and forged pistons/rods?
I just saw an example of a bill from the only reliable vq35de machineshop here in the Netherlands and a new cylinder block without machining will cost me around the same amount of money...
Thnx,
Reinier
Old Oct 7, 2010 | 05:01 AM
scenehouser
ok did some searching which i should have done earlier (;
seems cylinders en pistons will never be spot on so there is always machining involved..
someone correct me if i'm wrong.
Old Oct 7, 2010 | 08:16 AM
rcdash's Avatar
rcdash
Correct.
Old Oct 7, 2010 | 08:51 AM
tonyzS/C03's Avatar
tonyzS/C03
IMO if your going to do anything its best done right the first time so I would just spend the money to machine the block, even if it is oem there may be some imperfections in it and with a good machining it will eliminate or at least reduce any issues that you might run into. GL with the rest of the build.
Dsowe
Feb 17, 2021 10:38 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
SharX59
Sep 27, 2015 09:23 AM
