G35 Twin Turbo Project
Old Dec 29, 2010 | 08:53 AM
  #81
Jattus's Avatar
Jattus
As far as fuel goes, I'm using a big 7th injector, and also utilizing the OEM 6 injectors. This is also giving great stock like drive-ability and gas mileage off boost. I am also using a external 2bar MAP sensor to go along with the fuel controller. Dynoed the car at 8psi yesterday and was getting some good power down to the wheels! I'm also at about 60-70% duty cycle to get the flat 12:1 curve, and w/ the fuel pump, I can probably squeeze another 30-40whp out before the fuel system is topped out, so this is a good level with this kit I believe. The air intake temps were also still good like last time after all of the dyno runs. Also, someone was curious about the turbochargers, they are td05-big16g's and they are legit!
Here are some pics and some videos...
Dyno graph showing the 5psi pull from a couple days ago, and the 8psi pull now...
Here is a video of a pull at 5psi from a couple days ago...
http://www.youtube.com/watch?v=N-1Vh2qG2jA
Here is a video of a pull at 8psi from yesterday...
http://www.youtube.com/watch?v=aWJp2ISPalk
Old Dec 29, 2010 | 09:40 AM
  #82
str8dum1's Avatar
str8dum1
pics of how you installed the 7th injector. how are you controlling it?
Old Dec 29, 2010 | 09:53 AM
  #83
CRIDDA's Avatar
CRIDDA
missed this, but like that you guys are trying something different
Old Feb 13, 2011 | 08:49 AM
  #84
biggersNISMO's Avatar
biggersNISMO
Bump.
