C/R 8.8:1 or 11:1 with FI application?
Old Sep 7, 2011 | 01:44 AM
Resmarted's Avatar
Resmarted
Originally Posted by maXmood
i went and bought the 8.8:1 cr, because with our environment, stock cr pistons are **** to detonation with a little adjustment to timing.. so it's gonna be really bad to go with higher cr.
i put the build on hold since it's summer time, but now the weather is changing, i guess it's time to start now.
Just noticed how hard this thread got bumped...
Old Jul 5, 2020 | 03:58 PM
yoshi350z's Avatar
yoshi350z
my 03 superchrged 350z has built bottom end (8:8:1) makes 440-450 whp at 10 psi
Old Jul 5, 2020 | 04:57 PM
0taku's Avatar
0taku
It's 2020, all about the high compression now.
11:1 or bust.
Old Jul 5, 2020 | 10:17 PM
bealljk's Avatar
bealljk
9years later ...
I'm running 9.1 to 1 ...
I think engine management has gotten better and we can detect knock easier than back in the day.
On the flipside - turbo technology has gotten better, smaller turbos can flow more air, bigger turbos can spool-up faster, more options of blowers are on the market, and prices have come down on turbos overall.
Anything from 8:1 to 14:1 ... why American is the best country in the world!
Old Jul 6, 2020 | 04:49 AM
Conway_160's Avatar
Conway_160
It's all about 10.3 (stock)+ lower compression give you a larger margin of error, with modern technology the ECU can catch knock before damage should occur.
Old Jul 6, 2020 | 09:38 AM
OldManZ350's Avatar
OldManZ350
Turbo's are one thing, and a Centrifugal Supercharger is a whole different Animal........
Old Oct 15, 2020 | 07:10 AM
RENFRO's Avatar
RENFRO
I'm going Wiseco 11:1 with their boostline rods, dynosty billet girdle, L19s, Tomei HGs, and a garrett G35-900 on my momentum kit. Plan to shoot for 500-550 on low boost 93 pump and 700ish on high boost 93 + boostane additive.
Edit: I called Wiseco today to confirm the 11:1 96mm pistons don't have material removed for weight for an NA application. They do not, and was told I'm completely good to go at the power levels above.
Old Oct 15, 2020 | 03:57 PM
0taku's Avatar
0taku
They do the boostline for the VQ? I don’t recall that unless you’re doing a custom order.
Old Oct 16, 2020 | 03:02 AM
RENFRO's Avatar
RENFRO
Yes, sir, they do. Haven't seen anyone running them yet, so I might be one of the first.
Edit: Only for the DE and VR38DETT. No HR support yet, but I imagine it will come.
Old Oct 29, 2020 | 07:44 AM
OldManZ350's Avatar
OldManZ350
Also Try Klotz.... HiTrate, Good Stuff
14 oz's in per Gallon, make 93 pump into 106 Octane Race Gas.
I used it a lot and it worked great.
Added 1 Gallon to 9 gallons of pump gas and make 10 gallons of 106 for $47, on bad.
350 Rookie
Apr 7, 2008 08:46 AM
Daking350z
May 11, 2006 05:56 AM
booger
Oct 1, 2004 12:10 PM
Houston G35
Jul 26, 2004 09:59 AM
