Garrett compressor covers
Vendor - Former Vendor
No, THIS is a B cover:
http://www.atpturbo.com/mm5/merchant...egory_Code=GCH
THIS is a Nissan cover:
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
I've played with hundreds of turbos and I honestly have yet to see a housing smaller than a T04B housing for the larger turbo's. The smaller T3 turbo's however get the tiny .42 A/R compressor housing which is super compact but it only goes up to a T3 Super 60 ( which is not too bad, it can push over 650whp on a twin setup and it's pretty cheap ).
huh, they obviously used a saw and welder the turbo in the pic which you find accpetable...
and special flanges dont mean anything either with a saw and welder.
Slight misunderstanding I think..
vr3 got twin 5557's to work in there. That is the setup i think would be ideal for my goals. I'm happy with what i have (once i get it back up and running) but the 5557 twins would be sick.
https://my350z.com/forum/shop-builds...n-93oct-3.html
ahh ok. well obviously saws and welders shouldnt be left to the customer. HAHA
You could get the same power curve using a standard easy to install greddy 20g kit as well. that 6765 is a better choice in terms of install and powerband, once you get running again
Also, those headers are custom, and I am trying to stay away from that. The idea is to have a TT kit that anybody can install themselves without having to remove the motor, relocate a bunch of stuff..ect. Bolt on is the key, just like the ST kit you have on your car now.
I ask because if you wish to make an economical kit you could go with twin T3 60 trims Stage 1 with a .48 or .63 turbine housing and it should not only spool pretty good but power output could go as high as 600whp. Each turbo is about $600 too.
Yeah, not sure about the T3 fitment, it is much larger than the T25
at that point, you have to decide what's more important. a 1 time install, or slower spool that happens everytime.
BP has a nice niche market because his kit doesnt extend the uppipe any further than options already on the market. But the TT kits hang off the exhaust ports essentially. Theres no denying that spool will be effected, and to the extent it would be hard to say.
Pulling the motor is very easy, so i would not let that drive your decision. Plus if you were looking for a better powerband than is already offered in his single kits, you have to pull the motor anyhow to get it built...
but i think point of a BP twin turbo kit is to have a fairly easy install without having to pull the motor, which seems to be general consensus on how to properly install a greddy kit. Ultimatley getting you a fatter powerband than his single kit without the install headaches of the APS, Greddy, etc...twin kits.
As far as pulling the motor goes, it is not only during the install. What if you have to service a turbo. A friend of my had the GTM built motor with APS TT kit on, and one of the turbos blew. He took the car to a shop, replaced both turbos and the bill was $12,000 for parts and labor. Not to mention down time. Just something to consider I guess.
I know that I would hate having to pull the motor to service a turbo, and I am sure most feel the same way, easy or not.
sorry youre right, the B cover is the smaller one, its been almost 4 years since i sold my POS APS ST kit, i think it had that cover. i actually still have it sitting around if you need it to try out. you can have it.
You have the turbo or compressor cover? I think the turbo is a T3?
I had a T3 50trim stage1 .48 in my garage about 2 months ago and it was pretty tiny.
Hmmm interesting...I should take turbo donation for fitment tryouts..
Can you fit turbos with a higher horsepower limit than this with the design you have in mind?
