HKS F-CON SZ Vs Uprev
Old Jan 3, 2011 | 08:42 PM
rocks's Avatar
rocks
Why because a MAF system works fine. With a good wastegate you do not need overboost. The only thing I will need on top of a revup is a msd 2 step, to build boost to launch the car. Uprev also controls my cam angles on my revup. I have tuned my cams. Been shifting my car at 8000 rpms for a year. I beat the hell out of it NA for 55k miles. The only system I would consider would be a haltech on top of the Uprev. Use the uprev to tune the cams among other things.
Old Jan 10, 2011 | 12:54 AM
pez1111's Avatar
pez1111
Originally Posted by Cookbot
Thanks for the answers, I searched for quite some time, but I always know I'll get good info. Going to plump for the uprev...well if I can figure out a solution to fitting the SC bracket!
I have a pre 2006 HKS/Rotrex supercharger kit and a 2006 rev up engined 350z. Where the bracket should fit, it's almost like it my engine has 2 cam shaft sensor areas and is a different shape to the one that will fit in the bracket.
This one would fit my bracket. See the 2 tear drop shaped covers.
My engine looks similar, but has larger pain in the **** ones with an electrical connectors on them and so fouls the bracket.
Plenty of info in this thread about the HKS S/C. The kit does fit revup, the only issue will be drive belt setup and ecu- ( cam timing on inlet and exhaust on the revup). Bracket is no prob.https://my350z.com/forum/forced-indu...tallation.html
Old Jan 10, 2011 | 02:49 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I would take the Uprev flash over the Fcon SZ. The HKS VPro I would prefer over the flash for high boost applications.
As someone suggested, there are pros and cons to eashc system. After taking our feedback, make sure to consult with your tuner and make sure they are comfortable with the system you prefer to use.
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
