Vortech install = Car wont start
Old Dec 30, 2010 | 09:35 PM
RetchedOne's Avatar
RetchedOne
Default Vortech install = Car wont start
I just finished my Vortech install..
2005 Z, New Kit from Vortech
I've gone through teh directions 3 times...
Double checked fuel lines
Triple checked my wiring...
Removed butt connectors and soldered all leads...
Car turns over, bumbles and stops.
I dont think it even "starts"
Spark plugs werent touched...
I'm 99% sure there is fuel present as the fuel lines are hard (were soft prior to initial start attempt)
Plan to troubleshoot further -
(it's 22 degrees outside, and my garage doesnt have heat, and my propane tank went dry... so i'm done for the night)
Bypass Vortech FMU, to see if it starts...
If that doesnt work -
Remove the Timing controller, and remove the COG belt...
IF I remove the timing controller (Resolder the ECU back to stock) and remove the COG belt, can i drive like normal?
I need to drive the car home tomorrow, working or not...
Old Dec 30, 2010 | 09:39 PM
kajuraelai's Avatar
kajuraelai
more information.... did you upgrade anything else? bigger injectors? new fuel pump? just making sure...
Old Dec 30, 2010 | 09:40 PM
RetchedOne's Avatar
RetchedOne
nope. direct from vortech and onto the car.
I plan to, but before i kill my warranty on the kit, I wanted to run it stock for a week or two.
MDK's Avatar
MDK
Yes.
I never used the SS box so I'm not sure, but I was under the impression that it needed to be programmed before you would be able to run the car. Am I wrong?
Old Dec 30, 2010 | 09:41 PM
RetchedOne's Avatar
RetchedOne
I believe it is ready to run in its stock form, for the 3.33 pulley, which i have on for now. the programming port has a "dont touch me" sticker on it that says not to break this seal...
Old Dec 30, 2010 | 09:42 PM
RetchedOne's Avatar
RetchedOne
and the directions mention nothing more than "hook it up"
Old Dec 30, 2010 | 11:29 PM
MDK's Avatar
MDK
Alright, just a guess.
If you have fuel and the engine cranks, the missing ingredient would be spark. You could try pulling a coil pack and see if you get a spark when you turn it over. If you do that it also wouldn't hurt to pull a plug and sniff for gas to make sure its actually making its way to the combustion chamber.
Is there any way to tell if the ss box is powered up and functioning?
Could you possibly have blown a fuse on the car while soldering the ss box in?
Old Dec 30, 2010 | 11:32 PM
RetchedOne's Avatar
RetchedOne
I dont know how to tell if the SS box is powered up...
I'll check all the fuses tomorrow morning, but the battery was fully disconnected while working with teh ECU.
Old Dec 30, 2010 | 11:44 PM
RetchedOne's Avatar
RetchedOne
I Did add a motordyne 5/16ths spacer....
Forgot about that...
Old Dec 30, 2010 | 11:52 PM
RetchedOne's Avatar
RetchedOne
one weird thing is that the SS Box does say G35 on a sticker...
Old Dec 31, 2010 | 06:17 AM
djamps's Avatar
djamps
Check the FSM for the correct wiring pins on your stock ECU for each spark plug. You might have grabbed the wrong wires if you went strictly off Vortech's instructions, each year/gen is a little different.
Old Dec 31, 2010 | 07:07 AM
binder's Avatar
binder
doesn't matter. did you count the pins for the correct wires? Coloring varies from car to car sometimes so never go by colors.
I told you not to screw with the harness and just do osiris.
Old Dec 31, 2010 | 08:06 AM
RetchedOne's Avatar
RetchedOne
i made my appointment for january 11th for the Osiris flash... i may just move it up a week...
I counted the pins, and the colors did match up. I even counted a 3rd time...
I'm going to go out and count a fourth time and grab my FSM and see if theres any discremancy's.
Old Dec 31, 2010 | 08:44 AM
binder's Avatar
binder
hmm, that's odd.
it shouldn't be too far off the tune to at least fire up.
Old Dec 31, 2010 | 08:58 AM
RetchedOne's Avatar
RetchedOne
Got it running...
Note to future self...
When installing anything, re-plug-in ALL wires you unplug.
I unplugged teh Throttle position sensor to remove the manifold... And didnt plug it back in...
Fired right up...
Now the garage door is frozen shut... So i have to wait for it to de-thaw... dang it...
RetchedOne's Avatar
RetchedOne
Now to clean up my HUGE mess of tools... and put the front bumper back on...
Old Dec 31, 2010 | 09:07 AM
R3belzBRN's Avatar
R3belzBRN
glad to hear that everything went well before the newyear bro..
Old Dec 31, 2010 | 09:10 AM
RetchedOne's Avatar
RetchedOne
well.. that and i'm 75 miles from home/work... it's new years eve... and my wife thinks i'm installing new "exhaust"
Kinda hard to believe exhaust work caused teh car not to start...
Old Dec 31, 2010 | 01:35 PM
MDK's Avatar
MDK
Ahaha, thats excellent news. I've done that before... well actually it was the MAF, don't forget that one either.
Glad you got it running.
Old Dec 31, 2010 | 02:18 PM
binder's Avatar
binder
Got it running...
Fired right up...
that will happen. You have to get into a system of things so you don't miss anything.
and just kick the door, don't be a *****
