Twin turbo build fabrication/pics
Old Oct 1, 2011 | 12:42 PM
  #241
binder's Avatar
binder
Originally Posted by Boosted Performance
Jeff, you would want those in a T3 configuration correct, or something like this:
The V-band housing are now available in .64a/r and .82a/r. These would be easy to fit, much easier than a T3.
it's beautiful!
Old Nov 20, 2011 | 05:03 AM
  #242
aln's Avatar
aln
shame to see the ST kit's ordering has slowed down, I for one would have snapped that TT kit if it had been ready for when I wanted my TT. Looking back cost wise I should have held off and waited for you to sell the finished product (whenver that'll be) but at least I can drive a decently powered Z now Well done on the progress. I know a few people in the UK looking at the ST kit so maybe they'd be interested in a TT. This recession is annoying to say the least! Keep her lit!
Old Nov 20, 2011 | 08:11 AM
  #243
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Yeah, what can you do. The way I look at it is that I am not having to sit on inventory, pay staff, pay rent for shop space..ect. This is the same reason I am able to price my kits that much lower, retaining great quality.
As far as the TT kit goes, I do't know if I will even get back to it. At the moment I am working on the 76mm kit, and that will be more than anybody will ever need (I think). Once that is out of the way, I will focus on a possible bulk buy for 5 ST kits with the 62mm and 67mm turbo options.
Old Nov 20, 2011 | 08:26 AM
  #244
aln's Avatar
aln
Wow no TT Shame but you're probably correct in increasing the ST, 76mm
If you could draft one of the Z tuners in the UK I'd say you'd be able to swing 5 kits easy. Could I run a APS TT with a 76mm in parallel
Hope you do ok mate, the work you do is proper.
Maybe when I'm tired of the APS I'll swap it all out for a BP kit
Old Nov 20, 2011 | 08:31 AM
  #245
Boosted Performance
If you guys didn't drive on the wrong side of the road, it would be easy
The started and steerking knuckle is the problem, and there is no way I can build something to fit, by guessing where things are on a RHD car. Everything is just so tight with this platform.
Old Nov 20, 2011 | 08:48 AM
  #246
aln's Avatar
aln
true that, wouldn't mind driving on the right again *used to it.
Maybe just send one kit over and let a tuning place adapt it? Would probably be a few interested in that...
Old Nov 20, 2011 | 09:37 AM
  #247
binder's Avatar
binder
2" flex pipe all the way to the front. modifiable kit
Old Dec 1, 2011 | 05:50 PM
  #248
Row2K's Avatar
Row2K
Hey Boosted, just wanted to ask you something about the twin vs single mid mounted turbo. I would expect the single turbo setup to be lighter than the twin, is this correct or does all the extra wrap around piping make up the difference and the two end up weighing the same. Second can one use a dual exhaust with your single turbo setup, ie. hks dual or invidia dual, etc. Thx
Old Dec 1, 2011 | 06:33 PM
  #249
Boosted Performance
Because the two turbos (in a twin configuration) are smaller, the total weight of the two kits would be comparable. I think the twin kit would be a bit heavier, maybe 10-15lbs at most.
As far as the single kit goes, it is built to utilize any exhaust system that can be bolted up to the OEM Y-pipe. There are a number of exhaust systems out there like this, from single to dual where they split after the Y-pipe.
I have been looking at building an exhaust system to work with this kit out of aluminum. There are a number of plaes now that make aluminum mufflers, and the entire system would wigh about 20lbs. I have seen this on a couple of cars now, and it seems to work great.
Aluminum muffler:
http://vibrantperformance.com/catalo...oducts_id=1704
Old Dec 1, 2011 | 07:26 PM
  #250
binder's Avatar
binder
I had a borla true dual on mine. I had to make a custom y adapter to make it work. The borla was way too restrictive past 500hp though so I removed it. i still have the borla exhaust if you want it for cheap.
Old Dec 2, 2011 | 05:12 AM
  #251
Row2K's Avatar
Row2K
Cool, I'll prob end up doing the same with a custom y pipe. I have an invidia true dual that I love the sound of.
Old Dec 2, 2011 | 11:03 AM
  #252
binder's Avatar
binder
just know that anythign that is not a straight through type muffler will not be very nice with making horsepower past upper 400 range.
Old Dec 2, 2011 | 02:25 PM
  #253
Row2K's Avatar
Row2K
I actually found what you said about your true dual surprising. I would have expected all that extra cross sectional area from the second pipe to provide plenty of flow capacity on your borla dual. Didn't realize that the borla mufflers are so restrictive. I really don't know how good/bad the mufflers on the invidia dual are with FI...I guess ill find out in a couple of months
Old Dec 2, 2011 | 03:37 PM
  #254
Boosted Performance
The Invidia is fine. I made a custom down pipe for a local customer to work with the BP kit. Here is a thread/build:
https://my350z.com/forum/forced-indu...g-build-3.html
Quick pic of the down pipe:
Old Dec 2, 2011 | 03:53 PM
  #255
konrad's Avatar
konrad
thats nice man , I love your fab work,
Old Dec 2, 2011 | 04:18 PM
  #256
Row2K's Avatar
Row2K
Wow, that looks absolutely excellent , good job
Old Dec 2, 2011 | 04:28 PM
  #257
binder's Avatar
binder
Cross sectional area is fine. It's a problem with the muffler. The muffler is a baffled muffler not straight through design. So you could run 5" duals to that muffler and it would still restrict.
2 weeks after dynoing 540hp i changed the exhaust out to a modified exhaust with a SP cutout and i dynoed at 652hp at the same boost pressure. I only stopped there because the clutch slipped.
Also, my 8psi spring always ran around 11psi on spring pressure. It wouldn't ever go down to 8psi. I thought it was strange and a backpressure problem at the wastegate. After i changed the borla exhaust the 8psi spring was exactly 8psi on the money. So backpressure had to be high.
Old Dec 2, 2011 | 05:37 PM
  #258
Boosted Performance
Thanks, and really any exhaust shop should be able to do this rather quickly. Once you cut the X pipe right in the middle, all you have to do i put the 3" down pipe in a vice and squeeze it a bit. After that it is a perfect fit, and all you have to do is weld it up.
Old Dec 13, 2015 | 03:22 PM
  #259
CL_hiro_g37s's Avatar
CL_hiro_g37s
Following... Again Sasha keep up the good work!
Old Dec 14, 2015 | 09:23 AM
  #260
Boosted Performance
This project never really went anywhere, although I would be able to make this system as a custom "one-of".
