Twin turbo build fabrication/pics
Old Apr 14, 2011 | 03:00 AM
  #161
midz350's Avatar
midz350
Originally Posted by XBS
Busy with work! I started a RE investment company a while ago and have been super busy with the current market, not much time to play with the car - but I am slowing getting back into it
Hows the car running?
-George
I just got the parts for the 4th engine Hopefully this one will make it.
I remember PMing about me GTM TT kit two years ago like its yesterday.
Old Apr 17, 2011 | 12:47 PM
  #162
XBS's Avatar
XBS
Veteran
Wow number 4 huh? What have your failures been related too?
You are right that was 2 years ago! How time flies!
-George
Old Apr 17, 2011 | 01:16 PM
  #163
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I would have to disagree as that is not entirely true. Based on your logic, Nissan would then have to individually tune every car they produce, which is obviously not the case.
Now if you are running a standalone or piggyback engine management system, then yes I would agree you should have a tune specific to your build.
But....
One of the major benefits of flashing the factory ECU is you retain and benefit from all the capabilities the manufacturer as already designed. air temp compensation, altitude compensation, fuel temp. compensation, voltage compensation, etc. etc.
So if you have a production turbo kit, designed for a specific trim vehicle, and during your R&D process tune this vehicle utilizing the factory ECU (within an acceptable safety margin of course) then packages this tune and supply it with your kit - you can literally install the kit, flash the ECU and drive the car.
I believe there are plenty of GTM kits with their flash running around that can prove this point. Not to mention tuners like Dinan, and various EVO tuners that sell their tunes over the internet/mail.
Just want to make sure we aren't spreading wrong information that might scare some folk who don't know any better
In short, a properly pre-packaged tune that is used with the kit it was designed for is no more dangerous, and if not safer (due to incompetent tuners abroad), than a custom tune.
-George
Have to disagree with this statement. Nissan has a flash for all Zs from the factory bc they all have the same hp. No mods etc. My bone stock Z was running extremely lean almost unsafe when I baselined my car. However a friends z was running real rich. That alone should tell u a generic flash is useless. Why invest thousands in power then cheap out on a tune for your specific tune/climate etc.
Old Apr 17, 2011 | 01:51 PM
  #164
XBS's Avatar
XBS
Veteran
Then there is something else wrong with your car, the flash is tuned for a certain range of power, and as long as you do not exceed that range you will be fine. (Therefore differences in power are irrelevant)
What where the specifications of your car? Turbo kit/EMS/Fuel/etc.
Old Apr 20, 2011 | 08:11 AM
  #165
binder's Avatar
binder
the only problem is the fuel compensations only work when the car is in closed loop. Open loop mode has no fuel adjustments and is static therefore if built engine A flows more than built engine B then that same tune will be lean with built engine A.
Factory engines can vary as much as 10% on power. Built engines would be in the same ballpark if not more variation due to the fact that there are different machinists working on the extra engines.
Out of the box tunes are generally going to run rich with retarded timing so the engines are "safe". This is far from ideal compared to getting a tune specific for a vehicle. 8 grand for a twin turbo kit plus the install and supporting mods so the 600-800$ for a dyno tune is well worth the weight of the cost.
Old Apr 20, 2011 | 11:06 AM
  #166
XBS's Avatar
XBS
Veteran
Jeff,
I believe we are talking about stock block buying a complete turbo kit including ems vs. a tuner kit with a custom tune. If we keep changing the scenario of course things will change if you are spending the money to get a built engine and turbo system it would be silly not to get a custom tune as well especially if you are exceeding the kits recommend boost pressure for that specific tune.
If anything the tune will be safer with a built engine due to lower compression and stronger components - so I still stand by my argument, although I do understand your perspective
Also just to clarify I was responding to the comment that not getting a custom tune is dangerous/going to blow your engine and that you should never use one (which is ridiculous). I am not arguing the fact that a custom tune will yield the most performance per individual car.
-George
Old Apr 20, 2011 | 12:51 PM
  #167
binder's Avatar
binder
Jeff,
-George
ah, i didn't know we were talking about stock block. I just assumed people have realized a twin turbo setup with the ability to pump out 800hp is a waste of money on a stock block.
I do agree an out of box tune can be a SAFE tune. They generally are over safe because of liability from the manufacturer.
We were just on different pages.
Old Apr 21, 2011 | 01:00 AM
  #168
XBS's Avatar
XBS
Veteran
Thanks what I figured Jeff, no hard feelings
Old Apr 22, 2011 | 07:02 AM
  #169
phantom617's Avatar
phantom617
subscribed!
Will the twin turbo kit also be able to work on a 05 6mt G35 coupe? If so I'll be in touch next tax return time
Old Apr 22, 2011 | 07:29 AM
  #170
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by phantom617
subscribed!
Yes, this will work with the auto as well. At the moment the project is on the shelf do to time/funding. The car will be going back on the road May 1st, and I don't plan on doing any R&D with the TT idea untill late in the year. At that point it will be completed, and ready to go.
I do have 4 ST kits ready to go at a great low price .
Old Apr 22, 2011 | 07:34 AM
  #171
phantom617's Avatar
phantom617
great that gives me ample time to put funds together and patiently wait for you to say they're ready for sale and I'll be in touch to figure out the best options and such and send payment
Thanks
Old Apr 26, 2011 | 09:34 AM
  #172
phantom617's Avatar
phantom617
one more question... would I be able to retain the use of DC sport ceramic headers and Motordyne Engineering ART resonance test pipes? or will I need to get different headers and test pipes when I do the install of the twin turbo kit?
Old Apr 26, 2011 | 10:09 AM
  #173
Boosted Performance
For optimal performace aftermarket headers are a great investment, so keep them for sure. The turbo(s) will sit in the place of your test pipes, so those would have to go.
Old Apr 26, 2011 | 10:14 AM
  #174
phantom617's Avatar
phantom617
oh sweet! I have no problem ditching my current test pipes. I have Kinetix resonated test pipes and they're still raspy on my car so I was thinking of switching to the ART pipes to eliminate the rasp but if the turbos take the place of the test pipes then that just saves me money overall
Can't wait til this winter to discuss options and send funds for this. I'll be keeping a close eye on this thread
and thanks for the quick replies I know your're a real busy guy so I appreciate you taking the time to answer
Old Apr 26, 2011 | 12:10 PM
  #175
binder's Avatar
binder
not to thread jack but it's probably your exhaust causing the rasp. I have unresonated cheapo test pipes with borla full exhaust and i've never had rasp from day 1. It seems most people with rasp have a straight through design or a single 3" exhaust.
Old Apr 26, 2011 | 12:25 PM
  #176
phantom617's Avatar
phantom617
I sent u and email so we don't go off topic here
Old May 19, 2011 | 06:31 AM
  #177
phantom617's Avatar
phantom617
BUMPING this thread so we don't lose sight of it
Old Jun 1, 2011 | 08:32 PM
  #178
RemiZ33's Avatar
RemiZ33
How far did you make it with the prototype for this kit?
Old Jun 1, 2011 | 09:12 PM
  #179
Boosted Performance
I have a local guy that would like to run a couple of GT2871R's on a built G35. Time however is a bit tight for me, so we are trying to work something out.
Old Jun 3, 2011 | 10:52 AM
  #180
RemiZ33's Avatar
RemiZ33
Sweet. I'm dying to see the kit and the numbers it puts down. Been slowly building the support mods in anticipation of your twin kit. I'm anxious to see how it all fits together.
