600cc vs 800cc max power
Old Jan 19, 2011 | 10:37 AM
jmicaelk's Avatar
jmicaelk
Question 600cc vs 800cc max power
Hi guys, I just wanted to see how much power I should be able to get out of some 600cc vs 800cc injectors. They are for 2 different engines, the first one I would like to get about 500rwhp and the second 600rwhp. I have a feeling that 600cc won't take me to 500rwhp, but 800cc should take me to 600rwhp, but maybe I should sell the 600cc and move the 800cc to the 500hp engine and get some 1000 cc for the 600hp engine. Any thoughts on this ??
Greddy 18G kit, with AAM stage 2, built block on both.
Thanks
Old Jan 19, 2011 | 10:43 AM
str8dum1's Avatar
str8dum1
you want to run the biggest injectors that your EMS will idle. Theres no bigger waste of money than having to keep buying new injectors.
I'd run 1000s or 1200s on both setups. PTE 1200s are inexpensive and idle great.
I wouldnt trust a single pump at 600whp. Thats too close to wide open.
Old Jan 19, 2011 | 10:54 AM
jmicaelk's Avatar
jmicaelk
So, 600cc won't get me 500hp, but how about 800cc ??
What EMS would you recommend for this I got a Utec before but that one needs to be scratched. How about an UpRev ??
Is RC1000 good enough for 600rwhp ??
Thanks
Old Jan 19, 2011 | 11:35 AM
str8dum1's Avatar
str8dum1
if you use uprev, you have to use high Z injectors, either DW or Injector dynamics.
Otherwise ProEFI or Haltech are the big main choices for unlocked EMS's
Utec wont idle those injectors very well without a Uprev reflash becuase it relies on the stock ecu for out of boost control and starting.
I'd use no less than 800cc for a true 500whp and 1000cc for 600whp.
Old Jan 22, 2011 | 02:40 PM
wannabuy350z's Avatar
wannabuy350z
single pump
800cc dw
gt28s
got 523 @17psi on a mainline dyno with 72% DC
Old Jan 27, 2011 | 01:31 PM
DMK's Avatar
DMK
Originally Posted by wannabuy350z
single pump
800cc dw
gt28s
Are you running a return fuel system?
Possible to hit 500whp with single pump and 600cc dw?
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
