Stock gears best for FI??
Old Jan 24, 2011 | 01:39 PM
getnsidewayz's Avatar
getnsidewayz
Default Stock gears best for FI??
I'm just curious as to what gears are the best for a boosted Z?
Any input would be appreciated!
Thanks,
Jacques
Old Jan 24, 2011 | 01:52 PM
Barnabas's Avatar
Barnabas
National Z Club President
need allot more information...
Power level?
What you use/goals for car are
Manual/auto?
Size tires and rims?
Old Jan 24, 2011 | 02:27 PM
getnsidewayz
Default Here u go
Right now I'm about 430rwhp, eventually gonna go for 600ish
Gonna be running 19x9.5 and 19x10.5
255 fronts 295 rears.
6 speed MT
Pretty frequent trips to the drag strip
Old Jan 24, 2011 | 02:29 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
6 speed MT
My set up is identical with about the same power. I have the auto 3.3 gears and like it, 3.5 would work fine as well, but that is as high as I would go.
Old Jan 24, 2011 | 02:33 PM
Barnabas's Avatar
Barnabas
6 speed MT
for your power level stock manual gears are perfect
3.3 would start to be beneficial when you get into the 550+ range.
The ratio will feel slower if you go to 3.3 without enough power since it takes more to get it to get up and go, so you cant realize all the benefits of the gears.
Old Jan 24, 2011 | 04:58 PM
getnsidewayz
thanks for all the input, im glad to attain this info. good stuff to know later down the road!
thanks again,
JAcques
Old Jan 24, 2011 | 05:47 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Stick with stock till you make over 550whp then go 3.3. Some guys even like the stock 3.6 for over 550whp . i guess i have even talked to guys that have 3.9 and 475whp and they loved them i guess it has to do with personal preference how you drive and what you use the car for. I have 3.3 and I think it helps me keep the power to the ground in the first 3 gears.
Old Jan 24, 2011 | 06:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
What tires do you have for the strip since you go often? What do you run now?
Old Jan 24, 2011 | 07:08 PM
6 speed MT
Then you can not estimate at what RPM you will cross the finish line. Get 600 horsepower first. Get new tires first. We will figure out the gears later.
NOTE: 600 horsepower and 19 inch DOT tires will be interesting.
Old Jan 24, 2011 | 11:57 PM
vnarang's Avatar
vnarang
This may be a dumb question, but I have aftermarket 4.08 gears. This wouldnt be recommended at all then with FI, supercharged or turbocharged would it? Even if I wanted like 400-450hp max??
Old Jan 25, 2011 | 05:24 AM
neverenough's Avatar
neverenough
600 whp on 19s is scary in cool weather. I run r888 295-30-19 that is an R compound tire as my daily and at the track I run MT ET RAdials 275-60-15 that is about 28x11.5 .
Old Jan 25, 2011 | 05:46 AM
getnsidewayz
Where in Louisiana do u live? I live i'n Morgan city. Also the 19s will just be my daily driving set. Drag trips I plan on having another set.
I still have a few things left to do with the car, will be upgrading clutch/fly within the next week or so and then picking up a set of rim/tires for track use.
I ran an easy 12.7 on stock rim/tires and stock clutch Knowing the clutch wasn't gonna last long haha.
Old Jan 25, 2011 | 06:04 AM
ttg35fort's Avatar
ttg35fort
Professional
No, getting traction in first and second gear is already difficult with FI on DOT tires. With 4.08 gears, add 3rd gear to the list. If anything, I would go the opposite direction, maybe 3.3 like Sylvan Lake V35 indicated.
Old Jan 25, 2011 | 06:10 AM
350Z400rwhp's Avatar
350Z400rwhp
With a supercharger it would be good. I'm considering this as an option for my supercharger setup. Gears will "feel" like a 10% boost in power and get to that high end powerband better. I know of a guy who has a 4.08 gear with his Vortech and I think there are a few more on here that also do. I wouldn't do gears with a turbo as there is already plenty of torque.
Old Jan 25, 2011 | 07:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What does that guy in his Vortech run?
I bet not as fast as the stock gearing Vortech best time.
While it may be cool to spin 2nd in a Vortech setup, and it would feel faster Id bet that 4.08 + Vortech is actually slower.
Old Jan 25, 2011 | 07:33 AM
getnsidewayz
I know there was a thread comparing all the gear setups with their top mph in each gear, would anyone happen to have a link to that?
Old Jan 25, 2011 | 07:49 AM
Alberto's Avatar
Alberto
Cranky FI Owner
yeah right here
www.gofawkingdoasearchyoulazymofo.com
Old Jan 25, 2011 | 08:14 AM
getnsidewayz
Default Lol
Originally Posted by Alberto
I would but I figured it would be alot easier for someone using a PC rather than me using my iPhone to navigate through forums.
Old Jan 25, 2011 | 08:24 AM
getnsidewayz
Default Lol
Err double post
Old Jan 25, 2011 | 08:41 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
https://my350z.com/forum/engine-and-...installed.html
