Vortech... but which exhaust??
Old Jan 30, 2011 | 05:46 AM
Erdem's Avatar
Erdem
Default Vortech... but which exhaust??
So I'm going built motor with a Vortech setup with 800cc injectors 928 impeller and 2.87 pulley, and my aim is 500Whp+
at the moment I have the Stillen true dual 2x2.5" exhaust installed.
and I've read several times on several threads that smaller exhaust is better for a supercharger setup, because it makes backpressure = higher boost
my question is, should I re-install the OEM exhaust back on, to make 500+hp or keep the stillen on?
and also anything else I should keep in mind to reach 500+ ??
Thank you guys in advance
Old Jan 30, 2011 | 06:09 AM
zerosec's Avatar
zerosec
oem exhaust ?
keep the stillen for sure... goodluck in ur project !
Old Jan 30, 2011 | 06:10 AM
Sodero's Avatar
Sodero
Just because your boost is higher doesn't mean you're power is..
What compression ratio are you going with for the engine? Consider getting cams??
If i were you I'd stick with the stillen exhaust.
Old Jan 30, 2011 | 06:11 AM
zerosec's Avatar
zerosec
more breathing mods u have the more u get out of the vortech, so i also suggest test pipes and headers...
Old Jan 30, 2011 | 06:18 AM
Erdem's Avatar
Erdem
CR is 9:1
I have been thinking about cams... I was little unsure about driving 1000miles untuned with upgraded cams to my tuner
Old Jan 30, 2011 | 06:47 AM
ramirj2's Avatar
ramirj2
You want CFM not psi the more air in and out with the correct a/f and timing, the more power you will get.
I have a stillen td and love it.
Old Jan 30, 2011 | 06:54 AM
Erdem's Avatar
Erdem
yeah I'm loving the stillen too actually sounds perfect when it gets warmed up IMO
Old Jan 30, 2011 | 07:53 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
i would go with either art pipes XYZ and 3" single or a full MD makeover
Old Jan 30, 2011 | 09:12 AM
redzblackh's Avatar
redzblackh
Not more power if your trapping the air in there. The more air u put in, the more you gotta let out. Keep the stillen, and get test pipes and headers. You'll be golden. And while your at it, get a higher flowing lower plenum and either the kenetix manifold or the motordyne spacer. You WILL notice the difference. Especially with the vortech
Old Jan 30, 2011 | 01:47 PM
walshtj's Avatar
walshtj
+1 except full MD.
Old Jan 30, 2011 | 02:30 PM
ashtrojan2008's Avatar
ashtrojan2008
"you get better horsepower with the stock"
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="480" height="390" src="http://www.youtube.com/embed/_PlYlLaxV38" frameborder="0" allowFullScreen></iframe>
sorry.. i had to
Old Jan 31, 2011 | 11:53 AM
tylerxfire's Avatar
tylerxfire
think u need to do some more research..i know where your going with that but still you need to flow exhaust and the stillen is much better than the stock...I ran stock headers, berk test pipes, motordyne xyz w/resonator, nismo s tune mid and tail section....sounded sick and worked great with what i had
which ems are you running?..id go smaller than those 800's, more along the lines of 600cc's, those are overkill and might cause issues with the car starting up correctly on cold or hot starts..just my 2 cents...
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
