G35 tt
Old Feb 2, 2011 | 04:37 PM
edunn252's Avatar
edunn252
Default G35 tt
Hey I have a 04 g35 and I want to go FI but I need some advice. I can`t decide between twin or single. This isn`t my daily driver and I want some ideas on what I should do with it. Im not looking at going crazy with the build but I would like some good power somewhere between 450-550whp. I want something to have some fun with on the weekends.
Old Feb 2, 2011 | 04:44 PM
usingthejohn's Avatar
usingthejohn
ebay has some kits that can put down over 550 rwhp
Old Feb 2, 2011 | 04:50 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Don't forget they come with blow off valves that sound really cool
Avoid the Turbonetics kit from there every other kit on the market twin or single should make 450-550whp, and everykit available has at least a few threads in this forum. i am a Jim Wolf fan boy because i had his 530bb kit great for a stock engine (it won't make the 550whp but his 700bb kit will) and now his 850bb kit and I have no complaints. For single turbo kits the boosted performance kit has a great price for a high quality kit and you can install it yourself in a day on jack stands. There are lots of other great kits that guys have had great experiences with as well just take your time and do some reading. Everyone on here has their own preferences as can make arguments for each kit available so in the end it is what works for you and you goals.
Old Feb 2, 2011 | 04:57 PM
djamps's Avatar
djamps
For 450+ WHP be sure to get your rods and pistons upgraded.
Old Feb 2, 2011 | 05:01 PM
usingthejohn
sylvan, youre right. hiw coukd i forget about the BOV?
op, on a serious nite, the only thing i will say is if younhave a sedan, do tons of researchbefore pulling the trigger. i did my homework, but still am in the middle of issues. just cause it says "g35" doesnt mean it is a bolt on. theres will be headaches.
then again, this basic info is something youd know if you read the stickied thread at the top, or read others numerous threads
Old Feb 2, 2011 | 05:42 PM
edunn252's Avatar
edunn252
im not buying a junk kit from ebay so i can have my compressor wheel blow up and destroy my engine. I have a coupe and I am a installer for custom shop. Doing the work isnt a problem i have my own shop and all the tools. Just wanted to get a second thought on things. Just looking around all i see is mainly the Jim wolf kits. I am most likely going to go with that.
Old Feb 2, 2011 | 06:39 PM
Glex25's Avatar
Glex25
Jim wolf kits are only sold and installed by dealers unless you buy used from what I understand unless they changed their policy.
Twin kits give you better low-midrange power
ST give you better top end
All depends on what you looking for
1/4 mile I give the edge to the ST
Road course/Track I give it to the Twins
I see you in Jersey, where abouts?
Old Feb 2, 2011 | 06:49 PM
edunn252's Avatar
edunn252
south jersey and i could probably get the kit through my shop. also im not looking at racing it just driving around on the highways and back roads
Old Feb 2, 2011 | 07:42 PM
thawk408's Avatar
thawk408
I would go for the Dreamworks Supercharger. It is by far, the best solution out there.
Old Feb 2, 2011 | 08:08 PM
Chako135's Avatar
Chako135
this.
Old Feb 2, 2011 | 08:10 PM
z2g's Avatar
z2g
https://my350z.com/forum/turbos-nitr...turbo-kit.html
Buy this and all your problems will be solved
Old Feb 2, 2011 | 10:13 PM
bbs350z's Avatar
bbs350z
go with powerlab or momentums new kit. simple and makes lots of power : )
Old Feb 2, 2011 | 10:55 PM
Pilot_Z's Avatar
Pilot_Z
Considering the quoted statements, it sounds like a SC system would be your best bet. If you don't want to go crazy on a build, I would keep your goal at 400-425 HP, keep a stock motor, and get a nice piggyback ECU. Once you get above 425hp, you'll need to build the motor and your costs go up considerably.
Good Luck, and let us know what you decide on.
Old Feb 3, 2011 | 04:15 AM
edunn252's Avatar
edunn252
I really want to go turbo though...also I was planning on building the block but not everything...from what i understand the stock connecting rods can handle quite a bit of power so putting new pistons in and fixing up the heads isnt problem...what do you guys think is considered a mild build on the engine?
Old Feb 3, 2011 | 04:40 AM
Glex25's Avatar
Glex25
Wrong
Wrong
Wrong
Who is feeding you this information?
The connecting rods is the weakest point of the VQ
Heads flow fine just add some cams
Mild build (Eagle rods/Wiseco pistons/ACL Bearings/ARP Mains/ARP L19 head studs/Cams)
Old Feb 3, 2011 | 06:23 AM
str8dum1's Avatar
str8dum1
a Boosted performance 6765 single turbo kit with a quick spool valve should become the standard single turbo kit out there. nothing could compete with it for the price and ease of install.
Old Feb 3, 2011 | 06:25 AM
Glex25's Avatar
Glex25
^+1
Old Feb 3, 2011 | 06:46 AM
superchargedg's Avatar
superchargedg
Damn Noobs
LOL havent heard that name in a long time.
Old Feb 3, 2011 | 07:25 AM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by Glex25
Wrong
Wrong
Wrong
+1000
Old Feb 3, 2011 | 09:06 AM
thawk408's Avatar
thawk408
The OG's remember it.
