SUPERCHARGERS with test pipes, ART Pipes and HFC's..
Old May 15, 2011 | 08:00 PM
djamps's Avatar
djamps
Originally Posted by binder
odd, i run open breathers on my engine and still have no smell.
truthfully, unless you have exhaust leaks your exhaust should exit the back of your car and not come into the cabin. so idk why you had weird exhaust smell.
When I hit boost I can smell the exhaust in the cabin if the windows are down... a little bit still circuilates back thru the vortex, maybe because I don't have a spoiler.
Old May 16, 2011 | 10:46 AM
binder's Avatar
binder
weird, i drive a lot with my windows down and don't notice a single thing. Maybe the vortex isn't fast enough to outrun the exhaust
but in all seriousness, iv'e never smelt anything bad in any of the straight piped vehicles (no cats) i've owned before or currently.
Old May 16, 2011 | 11:00 AM
djamps's Avatar
djamps
I have a G not a Z that might be the difference...
I think even when I was bone stock I could smell the exhaust during extended WOT runs (windows down of course).
Old May 16, 2011 | 11:19 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
jeff owns a G. I can smell my car when at stoplights with windows down
Old May 16, 2011 | 01:52 PM
binder's Avatar
binder
push the skinny pedal harder!
Old May 16, 2011 | 03:23 PM
Mr.Squeeze's Avatar
Mr.Squeeze
Originally Posted by _ink
I suppose I'd like to hear from supercharged owners with ART pipes... And what they think about it.
I don think many people have them on 350z's with vortech's.When I had my 350 I looked around like crazy, and I just decided to go with the ART pipes.
Old May 16, 2011 | 04:30 PM
evil00017's Avatar
evil00017
Originally Posted by chrisjersey06
That sounds like a poor quality part and shouldn't be associated with HFCs in general. My Kinetix are holding up just fine with the Vortech a year later with daily driving.
I was running berks which I think are good quality. The possibility of a bad batch always exists though. I think the amount of exhaust you are flowing, heat your generating and power your making plays a big roll in premature cat failure.
Old May 16, 2011 | 05:20 PM
_ink's Avatar
_ink
Cat failure is soo common, and i guess i want one thing less that i need to worry about and be paranoid about...
And if it gives you extra performance, and a more aggressive sound... WIN!!!!!!
Old May 16, 2011 | 07:04 PM
chrisjersey06's Avatar
chrisjersey06
Going by your sig, you're putting out about 40whp more than me, so maybe that's a factor? Beats me, but you're right, a lot of different factors play a role.
Common? Really? I've been in these cars for a good number of years and wouldn't call it a "common" issue. Its something that can go, and maybe can go easier than some other parts, but I wouldn't lose sleep over it or be paranoid. Some of us don't want the extra noise, smell, and inconvenience of having to change them out every year for inspection. I'm very happy with my HFCs and I personally think they were worth the extra money in my situation. If I went with a turbo instead of SC, I may have been persuaded to go a different route.
Old May 17, 2011 | 06:09 AM
Mr.Squeeze's Avatar
Mr.Squeeze
If I were you I would go with the ART's they are not as loud as resonated test pipes, and the flow just as well.
From your post this sounds like what you are looking for.
Old May 17, 2011 | 08:16 AM
lstierlen's Avatar
lstierlen
I can understand how Cats would improve boost in a turbo system, as the back pressure would force more flow to the Turbo, but I don't see back pressure improving air flow through a Supercharger, as this is run via pulleys and belts. It seems to me, in a Supercharger set up, you want wide open flow in and out. I have ART tubes, and dual exhaust and will be putting in a ProCharger in July. I will be able to post numbers with that set up then. Will be getting a 9# pulley, and will be dynoing with Osiris Tune at Able Racing here in OKC.
Old May 17, 2011 | 01:46 PM
binder's Avatar
binder
actually cats reduce flow to the turbo therefore reducing flow and power. If they are after the turbo they increase backpressure which will slow spool and reduce power just like a restrictive exhaust. It's proven that free flowing exhaust (ie: no cats) is a huge benefit in turbos.
Old May 24, 2011 | 06:26 AM
_ink's Avatar
_ink
This would also be the case for superchargers right binder?
In that hp will increase, while boost decreases?
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
