Tapping into Injen intake
Hey,
I just started looking into nitrous, and I know with a wet kit you tap into the z-tube in between the MAF sensor and the TB. Obviously it's pretty easy because its plastic, but how do you do this if you have an Injen intake? I don't see how you'd tap into the intake tube if its metal. Is this what you'd use a TB spacer for and tap into that?
Just a question out of curiosity. Thanks to anyone who can clear this up for me
buy a Female Aluminum NPT Weld Boss
http://www.anplumbing.com/shop/index...dept=Weld!_Ons
and get it welded on. The intake tube would only get 1 or 2 threads if you just drilled and tapped that.
just tap it into you fuel supply line. at least you'll have the nitrous evenly dispersed to your cylinders. check this adapter out by z1.
http://www.z1motorsports.com/350_g35...oducts_id=3044
