AEM boost gauge reading
Old Jun 4, 2011 | 10:19 PM
fishclub's Avatar
fishclub
Default AEM boost gauge reading
My boost gauage read 20 at idle with the vortech set up, is that normal?
Old Jun 4, 2011 | 10:51 PM
meanz's Avatar
meanz
if its in the vacuum then yeah
Old Jun 6, 2011 | 01:11 AM
maXmood's Avatar
maXmood
Under Boost!
that's 20 below 0. means -20, which means vaccum. so, yeah. that's normal.
Old Jun 6, 2011 | 11:35 AM
binder's Avatar
binder
if it's positive 20 (20psi instead of 20mmhg) then you probably have your boost sensor between the bypass valve and the blower which won't show vacuum. That port on the blower is for positive pressure only and not for your "boost/vac" gauge. You need it on the engine side of the throttle body.
apex locator
Jul 23, 2021 02:27 AM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
