FS: APS TT Tuner Kit w/ GT3071 BB Upgrade
I'm selling my APS TT Tuner kit. This kit comes with the log style manifolds and single piece 3.5" down pipes. I've had the turbos upgraded to Garrett 3071s with ball bearing centers, converted to external wastegates and custom oil lines to bolt right onto the original mounting hardware for the kit. All work was done by Blouch Turbo.
Turbo specs:
Turbine - 84 trim, 56mm dia.
Compressor - 56 trim, 71mm diameter
.86AR
The manifolds, downpipes and wastegate pipes have all been coated with JetHot2000, not an imitation coating. The kit comes with Tial wastegates set up to exit into the exhaust pipes, but can easily be changed to an open dump setup rotating the WGs 180* and covering the exsisting ports in the exhaust.
The down pipes have 4 bungs for O2 sensors and a bung for an Innovate wideband as well. The turbo oil drain lines have been modified to drain into the upper oil pan just below the windage tray, so I will send the upper pan and all fittings and hoses with the kit. The modification was done because the normal APS setup usually seeps at the drain lines and the lines swell over time and look like they will burst (ask any APS TT owner).
Almost all of the mounting hardware was replaced just before my last install and all the couplers were just replaced as well. The intake is predrilled to accept dual meth inlets (will be sent with plugs installed). Intercooler is included with the kit.
This kit made 578whp on a dyno dynamics on 22lbs... that is roughly 640whp on a DJ!! With C/Q16 somewhere very close to 700whp or above should be attainable (based on supporting mods).
The price is $5200 obo.... but for that price you will also get freshly rebuilt turbos. The turbos have been dropped off today at Blouch for a full inspection and rebuild if needed. I will have Blouch ship them directly to the buyer so they can be assured that they are 100%. This is basically the APS Extreme Kit without the fuel system at a huge discount.
Link to the APS site for some pics and explanation. I linked to the Extreme kit because my setup had the similar manis and DPs like this looks. http://www.airpowersystems.com/350z/...s-09/index.htm
That was a lot of words... here are the pics:
Turbo specs:
.86AR
I need a better address please, UPS.com won't let me estimate shipping with that address. I would expect $500 min for shipping as its at least 3-4 boxes (it was two new) and I would think you would want insurance on the packages.
Service Latest Pickup
Time: Delivered By: Total
UPS Worldwide Saver
7:00 P.M.
Friday
June 17, 2011
By End of Day
Tuesday
June 21, 2011 - Guaranteed 1,799.29 USD *
Schedule by
6:00 P.M.
Friday
June 17, 2011
UPS Worldwide ExpeditedSM
7:00 P.M.
Friday
June 17, 2011
By End of Day
Thursday
June 23, 2011 - 1,217.09 USD *
Schedule by
6:00 P.M.
Friday
June 17, 2011
I finally got it... the google is helpful. This is crazy though, I think there is some kind of discount rate for soldiers stationed abroad. Could I ship it to your family in the US and they could send it to you overseas?
This pricing was using and est of 3 packages weighing 70lbs each with contents valued at $3500 total.
UPS Worldwide Saver
7:00 P.M.
Friday
June 17, 2011
By End of Day
Tuesday
Schedule by
6:00 P.M.
Friday
June 17, 2011
7:00 P.M.
Friday
June 17, 2011
By End of Day
Thursday
Schedule by
6:00 P.M.
Friday
June 17, 2011
The quotes were from UPS. Sorry, I would love for the kit to go to someone in the Armed Forces... almost all my parts have been sent to active military that are currently overseas.
If you can figure out reasonable shipping I can ship it anywhere.
bcoffee20
Nov 19, 2015 06:39 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
