Forged Performance: FP S1 Shortblock TT Results
Old Jul 15, 2011 | 10:19 AM
Chadbee@Forged's Avatar
Chadbee@Forged
Vendor - Former Vendor
Default Forged Performance: FP S1 Shortblock TT Results
Yesterday we had a customer make the drive from Indiana to our location for a complete Forged Performance calibration using the Haltech ECU. The car was strapped to our Dyno Dynamics Dyno and Sharif went to work. With nothing but start up time on the engine, Sharif also performed a 2hr steady state loaded engine break using our dyno. One of the greatest benefits of the Dyno Dynamics is the ability to steady state tune and perform engine break in before the car ever leaves the shop. This car came to us with the following modifications:
• Forged Performance short block
• ARP L19 head studs
• HKS head gasket
• Cosworth heads
• Supertech billet lifters
• Brian Crower stage 2 cams
• Cosworth intake manifold
• GTM stage 2 turbo kit with GT2871 turbos
• Greddy Evo TT exhaust with restrictions removed
• Haltech ECU
• Innovate dual wideband air fuel meter
• HKS 1000cc injectors
• CJM twin pump unit
• Koyo racing radiator
• Setrab oil cooler
• Stillen high capacity oil pan
• ATS Carbonetic triple disk carbon clutch
Final numbers were 517 HP 410 TQ @ 17psi using 93 octane pump gas. He will be returning soon for an E-85 tune and more boost, which should be very interesting.
Old Jul 15, 2011 | 10:44 AM
thom000001's Avatar
thom000001
Nice!
What flow increase do the cosworth heads offer over a stock head?
Tom
Old Jul 15, 2011 | 12:33 PM
Zivman's Avatar
Zivman
I would love an E85 tune on my Z!
Old Jul 15, 2011 | 02:35 PM
midz350's Avatar
midz350
What seats are those?
Old Jul 15, 2011 | 02:43 PM
bigcloud's Avatar
bigcloud
sparco's
Old Jul 15, 2011 | 03:28 PM
SmallTuner's Avatar
SmallTuner
cool
sharif looking good
Old Jul 15, 2011 | 07:42 PM
XKR's Avatar
XKR
Clean looking work...
Old Jul 15, 2011 | 09:05 PM
jtgli's Avatar
jtgli
Why is the tq so low for a DE?
Old Jul 17, 2011 | 11:13 PM
Resmarted's Avatar
Resmarted
Originally Posted by bigcloud
sparco's
WHO IS AVATAR?
cough uhhh cool car forged.
i want to see you guys make some more power.
Old Jul 18, 2011 | 03:37 PM
CFZ's Avatar
CFZ
This is my car and installation. Only broke in and tuned by Sharif and yes I agree torque is quite low. Anyone have any ideas as to why torque would be this low ?
Old Jul 18, 2011 | 04:21 PM
str8dum1's Avatar
str8dum1
the trq is low cuz the turbos spool kinda late. Reminds me of my original haltech tune.That trq curve is nice and broad so it should be great once in the powerband.
What you should do some quick logs of your boost curve. Super easy on the haltech.
Log 3x 3rd gear pulls from 2000rpm until redline on a flat or slightly uphill road. try to do all 3 pulls on the same section of road and make sure to do at least 3 without turning the car off.
then just double check that every logged boost curve looks like the one in the dyno. The boost should be pretty similar, ie 16psi at 5250, etc etc...
The parts list looks good on paper. Hopefully those heads arent slowing exhaust velocity down too much, which would also kill spool.
Old Jul 18, 2011 | 05:43 PM
projektZ's Avatar
projektZ
Nice build. You could nearly eat off that engine bay!
It is interesting how low your torque is though. My Z recently put down similar hp #'s as yours but my torque was much higher (I am using same built motor, BC Stage 2 cams, stock valvetrain, stock intake plenum) - 516 whp & 479 Ft-Lb on a mustang dyno at 13 psi. Not sure how the mustang dyno compares to the Dynamics. I was told that the plenum spacer or the cosworth intake that you have should help with the torque.
I was limited with the Utec/600cc injectors/walbro fuel pump. I intend to upgrade all three at some point but it is nice to see how other setups compare.
Old Jul 18, 2011 | 07:11 PM
CFZ's Avatar
CFZ
Thanks for the complements guys.
str8dum1, I checked my Haltech logs from the dyno session and boost curve is pretty simalar from 1 pull to the next +- 75 rpm. I will do some logs on the street and see what those look like. What does it mean if the boost curves are not similar ?
Thanks for the help
Old Jul 18, 2011 | 07:16 PM
Ruthless18x's Avatar
Ruthless18x
Awesome setup. The E85 should be exciting.
Old Jul 18, 2011 | 08:17 PM
rcdash's Avatar
rcdash
why are 2871s spooling late?
Old Jul 18, 2011 | 08:42 PM
midz350's Avatar
midz350
The GTM stage 2 turbo kit comes with GT2860rs .86 AR turbos.
Old Jul 19, 2011 | 03:44 AM
CFZ's Avatar
CFZ
It is the GTM stage 2 kit with 2871r turbos.
Old Jul 19, 2011 | 04:00 AM
midz350's Avatar
midz350
You wanna bet money on that?
Its Garrett GT28RS (aka GT2860RS) Ball Bearing Turbo aka Disco Potato.
Old Jul 19, 2011 | 05:44 AM
rcdash's Avatar
rcdash
Well that makes it even more unlikely to spool late. I would consider a leakdown test to make sure the engine is 100% ok (probably is but good to get a baseline anyway) and then go start looking for boost leaks. Maybe the run just started late. How does it feel on the street? Another good test to make sure both turbos are working ok is to hook up MAP sensors to the outlet of each turbo compressor.
Old Jul 19, 2011 | 07:05 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Lots of money on parts for not a lot of power.
