Another GTM Install
Old Aug 18, 2011 | 07:41 AM
  #61
rh_334's Avatar
rh_334
Originally Posted by jeffie7
For the people running 520-530WHP is that their everyday boost settings? How many miles have they been running it at 500WHP+?
I ran my 484-510rwhp boost setting everyday on a stock DE for over 8k miles before i went built.
EDIT:
Originally Posted by Cass007
Most people do the exact opposite with stock block power. They drive at or near their max whp and then up the boost occasionally because it is like crack. Then, one day its just your turn and... BOOM!! Very few are able to avoid this temptation (Jeffie and Keith are two of the few).
^THIS, luckily i pulled mine for the built block before i blew it
Old Aug 18, 2011 | 08:40 AM
  #62
John@z1's Avatar
John@z1
Z1 Motorsports
Originally Posted by nathanwl2004
never had any problems with forged, yet I got majorly screwed by z1 when they flat out lied to me about a garbage transmission they sold me. what I actually got was nothing even close to what they promised and I have the pictures to prove it.
as a matter of fact forged ended up replacing the transmission I bought from z1 when it took a total **** less than a year after installation.
I have never heard of this issue. Can you please PM me your info? I would love to check into this.
Old Aug 19, 2011 | 09:28 PM
  #63
Resmarted's Avatar
Resmarted
Originally Posted by f150intally
I do have one question for you guys. I have four gauges to mount and a boost controller. Being that I would like nothing showing in the cabin that would indicate I wasn't stock, where can I mount the gauges and boost controller? I think boost under the dash would be ok but not sure I can fit four gauges in the cubby above the radio. Suggestions?
Thanks,
Jay
use the oem 3 gauge cluster. then put the fourth and the controller in the cubby. that's what im doing except i only have 3 and my boost controller is in the haltech.
imo the oem gauges never really did anything for me. the multigauge is useful but afr boost and temp is much more important to me.
Old Aug 20, 2011 | 04:38 AM
  #64
f150intally's Avatar
f150intally
Sounds like a good plan. Is it possible to put the factory gauge unit back in if you had to take the car back stock?
Old Aug 20, 2011 | 05:27 AM
  #65
binder's Avatar
binder
so it's the day after your tuning appointment.....what happened
Old Aug 20, 2011 | 10:13 AM
  #66
f150intally
Actually, it was being dropped for install and tuning. I expect it to take a few weeks to install. I will be back up in September when they tune it. Videos, pictures etc as that happens. A lot of work left still.
Old Aug 20, 2011 | 10:24 AM
  #67
binder's Avatar
binder
ooo, i thought it was just going for a tune on the 19th
Old Aug 21, 2011 | 06:44 PM
  #68
Resmarted's Avatar
Resmarted
In theory yes, but that really depends on how you disconnect the stock gauges. I'm pretty sure you have to cut some wires so if you are willing to install m-f plugs or do some soldering then yeah it should be fine.
If you are going through the trouble to put things back to stock it shouldn't be too much of a hassle (unless you really butcher the removal).
Old Aug 22, 2011 | 01:35 PM
  #69
MDK's Avatar
MDK
Just buy a used one and hack that up. save your oem one to "go back to stock" if you worry about such things.
I was able to get a PLX gauge to fit inside of the oem housing with a bit (ok a lot) of careful cutting.
Old Aug 22, 2011 | 02:25 PM
  #70
350z-900whp's Avatar
350z-900whp
get hks NAVIGATOR or CAMP2. HKS navigator work well for me small screen that have all info u need to keep u eye on
Old Aug 22, 2011 | 11:49 PM
  #71
Resmarted's Avatar
Resmarted
you need an fcon for that...
f150 has osiris.
EDIT:
Or do you?
Old Aug 23, 2011 | 02:18 AM
  #72
suprasam's Avatar
suprasam
The camp2 gets some of its readings from the factory OBDII port like rpm, water temp, to name a couple. Other readings like oil temp, boost, fuel pressure, oil pressure require additional sensors. And then if you want AF then you need a knock amp connected to the FCON that will read on the camp2, but if you had the knock amp visible then you would need the display anyway. HKS website has more info on the factory sensors it can read. For me it is a good display considering in got the other do-dads too.
Old Aug 23, 2011 | 03:18 AM
  #73
midz350's Avatar
midz350
^ Instead of all that **** , just get a Haltech and a car PC.:dunno
Old Aug 23, 2011 | 04:55 AM
  #74
f150intally
You guys are cracking me up. Everything has been purchased. I do have OSIRIS but was just asking about using the factory gauge location and could i go back to mounting the stock gauges if the car ever goes back to stock.
On another note... I did not get to drop the car off because my friend that was going with me had a family emergency and had to bail. I am now driving to Z1 this Friday night and dropping the car off Saturday morning.
So, while I still have the car in my possession, I am going to the local dyno (Mustang Dyno) to get a baseline set of numbers. This Z is BONE STOCK. Let's play a game....guess my bone stock Mustang Dyno number!
My personal guess.... 243whp... the facility is climate controlled.
Old Aug 23, 2011 | 06:10 AM
  #75
John@z1's Avatar
John@z1
Z1 Motorsports
We will also dyno it
Old Aug 23, 2011 | 06:35 AM
  #76
sublimemoment's Avatar
sublimemoment
Old Aug 23, 2011 | 06:54 AM
  #77
f150intally
Cool John. I will talk to you Saturday about this but would like you guys to document (through pictures) the tear-down and build up since I won't be able to stop by in person during the process. I like to have things like this. I will hopefully be there for the tuning so I can record that, etc.
Thanks.
-Jay
Old Aug 23, 2011 | 07:50 AM
  #78
midz350's Avatar
midz350
259whp
Old Aug 23, 2011 | 09:45 AM
  #79
ace32x's Avatar
ace32x
Old Aug 23, 2011 | 03:48 PM
  #80
superchargedg's Avatar
superchargedg
Damn Noobs
