Another GTM Install
Old Sep 16, 2011 | 08:44 AM
  #121
binder's Avatar
binder
Originally Posted by str8dum1
i was injecting over 1L/min (15GPH) on my 1st build with no issues. Granted I had the flow to support that much injection
my point exactly!
f150, i'm aware it's 2 cores but it still could be easily routed to send the outputs up through the core support allowing a straighter and shorter piping setup.
Old Sep 18, 2011 | 07:53 AM
  #122
f150intally's Avatar
f150intally
Just a quick update.... me and my mechanic Will decided to do the A/F and boost gauges in the stock pod but I wanted a covert look and didn't want it to look like we just stuffed the gauges in there. So this AWESOME shop managed to machine the pod and retain the factory gauge rims after removing the rims on the Defi and Innovate Gauges. Oil Pressure and Water Temp gauges mounted in the glove box.
The top photo is before we made our decision. I don't have one lighted with everything after fact yet. He will send it to me on Monday.
Old Sep 18, 2011 | 09:17 AM
  #123
binder's Avatar
binder
Looks nice.
so the a/f took the place of the oem oil pressure?
what was the deciding factor with using a water temp gauge instead of an oil temp gauge?
Old Sep 18, 2011 | 12:51 PM
  #124
f150intally
Originally Posted by binder
Looks nice.
Correct. After getting hammered on the other thread about the accuracy of the stock oil pressure gauge I thought I would get something better. I don't race the car on road courses or lengthy track events and with the 34 row Z1 oil cooler I didn't think oil temp would be critical. However, the summers are quite hot in the panhandle and with completely stock engine cooling I felt more comfortable with a more accurate way to monitor coolant temperatures.
Old Sep 18, 2011 | 01:00 PM
  #125
binder's Avatar
binder
makes sense.
at 523 hp on stock cooling system even in 100* temps here in stl i've never had an issue with high cooling temps but my oil temps have skyrocketed before even with my oil cooler.
i didn't know the stock oil pressure was inaccurate but if people find it inaccurate i would have replaced it as well. I use a defi oil pressure sensor in my G because we don't have a stock pressure sensor.
Old Oct 1, 2011 | 05:02 AM
  #126
f150intally
Default Small Picture Update
Had the pleasure of visiting the shop again to check on the progress. Things are getting real close! Here are a few pictures.
Old Oct 1, 2011 | 10:39 AM
  #127
ace32x's Avatar
ace32x
looken good need some bigger wheels with more meat now!
Old Oct 1, 2011 | 11:11 AM
  #128
midz350's Avatar
midz350
I fwcking hate you
Old Oct 1, 2011 | 12:45 PM
  #129
f150intally
I will run bigger tires at the track but am keeping stock wheels for the street for now. I'm going tto run stock sized Yoko advan neova ad08s on the stock wheels.
Old Oct 1, 2011 | 01:06 PM
  #130
f150intally
I created a picture website which I will keep updated...
Jay's 350Z GTM Project
Old Oct 1, 2011 | 01:41 PM
  #131
binder's Avatar
binder
how much HP are you going to run?
Those 245's won't hold anything for power. I had 275 falken 452's and those were easy to let loose with my vortech. With turbo power you will have no traction.
Old Oct 1, 2011 | 02:13 PM
  #132
supernadc2's Avatar
supernadc2
Build is looking awesome bro, and you will enjoy it for sure. Going through the last few pages is like every other F.I thread on here, people get super opinionated but love to build there post counts an sh*t, just can't keep to themselves. There are tons of shops i would love to flame but doesn't make me any better of a person. I love the quality of GTM's kit and build. Sam's rep may not be the best out there, hell my car was there a little longer that quoted but his work speaks for itself. 3 years and my Z is running just as strong as the day i drove off from GTM. I am far more conservative on how 'often' not how hard i push it. Some douche bags on here expected to have 500+ whp on stock blocks and 'drive hard' all day every day and expected it to last. If Sam told them it was ok, they obviously didn't do the research others are telling you to do.
Anyways i myself am OT an apologize. Best of luck with your build. Looking forward to seeing your end results and another happy TT HR dude on the forum.
LOL .. i had to say though I'm dying at 275's on the tires. Highly suggest an upgrade VERY soon haha.
Old Oct 1, 2011 | 02:46 PM
  #133
ace32x's Avatar
ace32x
when i was stock block and ttd i was running 295 hankook evo 12s (not the best grippy tire mind you) but it burned through third i dont think those 245 yoko's will hold u down to well
Old Oct 1, 2011 | 03:58 PM
  #134
f150intally
Z1 is recommending Yoko Advan Neova AD08. I'm kind of torn on tire size. What is the biggest tire that fits on the stock wheel? In case you guys haven't noticed my build could be titled Covert350.
I have a second set of wheels for strip that I will run MTs on. As soon as the car gets home we are doing Akebono 370z brakes and quaiffe differential.
Old Oct 1, 2011 | 04:09 PM
  #135
f150intally
Hey bud. Thanks for the comments. Your build definitely inspired Me!
Old Oct 1, 2011 | 04:16 PM
  #136
f150intally
Shooting for 500whp on high boost. Normal driving on wg spring pressure of 6lbs.
Old Oct 1, 2011 | 04:25 PM
  #137
ace32x's Avatar
ace32x
probably 275s i wouldnt go bigger than that on the stock 8.5's
Old Oct 1, 2011 | 04:55 PM
  #138
binder's Avatar
binder
275's on the 8" rim? I don't think that will work. I ran 275's on a 10" wide rim.
I would say 255 will fit and maybe a 265 at most.
I had stock size on my car for breaking in my engine a few months ago. After the engine was good and broke in my tune for 10psi would light the tires up through 4th gear. It was dangerously violent too. That small of a tire doesn't slip like a drag radial so you can't really control it.
My car is a sleeper. Cant see the intercooler, completely stock outside except black rims and 305 mickey thompsons tucked away. Don't take the "sleeper" thing too far. There is a difference between stock looking and sleeper. Stock looking won't do anything if someone rolls on you on the highway. A sleeper on the other hand will hook traction and walk away. Can't be a sleeper if you're not actually putting power down.
Old Oct 1, 2011 | 05:27 PM
  #139
f150intally
The minimum recommended width is 9" for a 275. My wheels are 8.5". I bet it will fit. Anyone done it?
Old Oct 1, 2011 | 05:47 PM
  #140
dikspiel's Avatar
dikspiel
Chestons Toilet
sounds like a bad idea....why invest all the money into a turbo kit and neglect the only portion of the vehicle that touches the ground.
