Turbo Upgrade
Old Jul 27, 2011 | 08:07 AM
JS04's Avatar
JS04
Originally Posted by Mkriebs
Thanks for finally clarifying. What do you suggest we do then? Which kit should I keep an eye out for?
I would say look at the Powerlab 76S kit, but from my understanding thats a in house install from Intense.
Old Jul 27, 2011 | 08:21 AM
Mkriebs's Avatar
Mkriebs
Yeah, in house install is no good. Not paying for someone else to mess up the car.
Old Jul 27, 2011 | 08:53 AM
Highway Riding's Avatar
Highway Riding
Twins and be done with it....
Old Jul 27, 2011 | 10:09 AM
str8dum1's Avatar
str8dum1
^pretty much or a Boosted Performance or modified STS kit.
A properly designed single turbo to make big #s needs to be located where you can use a minimum of a T4 flange with a 4" downpipe (3" is probably find in a under the car turbo setup, but would want 4" for a PL/Momentum mounting position). Along with 3" charge pipe to the IC and throttle body.
So either rebuild the front of your car like HAL at Injected or use a mid mount or rear mount kit.
Otherwise, just go with a twin turbo setup and not have to modify anything.
Old Jul 27, 2011 | 12:33 PM
athens2jz's Avatar
athens2jz
I made 530whp stock tn kit with meth and 18psi built block no cams on a mustang dyno at Japtrix in 2008 open dumps and 600cc injectors and full supporting mods. But that was after a **** ton of tuning, time, and$$$. I was gonna upgrade the turbo but instead I bought a greddy Tt kit and on 10psi 450whp it pulls just as hard if not harder. Pretty much dont **** ur money away on upgrading that tn kit.
