Vortech Install... Final HP numbers!
Old Dec 11, 2003 | 01:04 PM
zimbo's Avatar
zimbo
Default Vortech Install... Final HP numbers!
My Vortech install is complete. I'm really happy with the job the shop (cpracing.com) has done and the time they have put into tuning the car after the install. I'll post the Dyno sheet later, but here are the numbers:
N/A: 264 HP at Crank (217 rwhp)
w/Vortech: 400 HP at Crank (328 rwhp)
After installing the kit, the A/F ratio was too low (about 9.0), but one of the chips in the kit is apparently computer programmable, so the tuner was able to set the A/F ratio across the RPM range to the 11/12 range.
Since I live about 3 hours away from the installer, I decided to have them go ahead keep the car tomorrow and over the weekend to do some around town driving to make sure that everything is good and that the car is going to be reliable. So, it's going to be Tuesday before I can go get the car. I can't wait!!
BTW, from what they tell me, the car isn't overly loud at idle, but the BOV is pretty darn loud when shifting at high RPMs.
--Steve
Old Dec 11, 2003 | 01:09 PM
ravaz's Avatar
ravaz
Steve,
Glad to hear it went well. Any torque numbers?
Bill
Old Dec 11, 2003 | 01:11 PM
g356gear's Avatar
g356gear
What are they using to re-program the chip??
Old Dec 11, 2003 | 01:13 PM
CaneZMD's Avatar
CaneZMD
That's awesome. 136 extra horses! Hurry up and get that
dyno sheet.......and the car so we can get some driving impressions!
Old Dec 11, 2003 | 01:32 PM
dollar99's Avatar
dollar99
Isn't the Vortech FMU mechanical? How can you tune it with a laptop?
Old Dec 11, 2003 | 01:42 PM
VelociTT's Avatar
VelociTT
i think they may have just wanted to joyride his car a lil
Old Dec 11, 2003 | 01:44 PM
fastvtecCL's Avatar
fastvtecCL
Default Re: Vortech Install... Final HP numbers!
--Steve
the final numbers
328.5rwhp and 282.3lbs of torque (to the wheels)
hey steve i can't wait to see your reaction when you drive the car
Old Dec 11, 2003 | 01:45 PM
fastvtecCL's Avatar
fastvtecCL
Old Dec 11, 2003 | 01:47 PM
fastvtecCL's Avatar
fastvtecCL
yes it was tuned by a laptop
azrael's Avatar
azrael
Very impressive.
Old Dec 11, 2003 | 02:04 PM
peptidbond's Avatar
peptidbond
Very nice G35 sedan. When I first read the numbers they didn't add up, but then I saw the sedan in your sig. Good idea leaving the car with the installers for a few days. Not all problems are evident right away.
Old Dec 11, 2003 | 04:50 PM
Zmeflyby's Avatar
Zmeflyby
how much was the kit and the installation?
nice numbers man
Old Dec 11, 2003 | 07:24 PM
bk_r0x's Avatar
bk_r0x
What PSI is the stock setup running at? fastvtecCL, I'm assuming you're the installer; any initial impressions as to fitment, tuning, etc. etc.? Any other mods on the car?
Old Dec 11, 2003 | 11:13 PM
G3po's Avatar
G3po
Default BOV
Good news. I would expect the BOV to be loud, given the open air venting. You may want to consider asking them if they could to plumb the BOV exhaust back into the
inlet tract after the air filter and before the compressor. This could quiet it down mucho.
Old Dec 12, 2003 | 04:43 AM
fastvtecCL's Avatar
fastvtecCL
it was runing 8psi.. i'm not the installer, i'm import sales manager. i did however help in the custom parts of the install
it wasn't very easy but we made it work as for the tuning part, it took almost all day to tune the car. it was runing VERY rich (mid 9's a/f) but with the help of undergroundracing's (our sister shop right next door) laptop comp and dyno jet.. we got the car runing great with the final a/f reading of high 11's to low 12's (12.1) all the way across the bord
Old Dec 12, 2003 | 05:29 AM
fastvtecCL's Avatar
fastvtecCL
here is the dyno sheet.... (working on making it bigger and clearer)
Old Dec 12, 2003 | 05:37 AM
fastvtecCL's Avatar
fastvtecCL
dyno sheet again.... hope this is better
Old Dec 12, 2003 | 05:41 AM
damen's Avatar
damen
congrats on the install and numbers.
Old Dec 12, 2003 | 05:52 AM
src5t's Avatar
src5t
wow, awesome numbers. when you get it back let us know how the beast drives!!
Old Dec 12, 2003 | 07:00 AM
blubyu's Avatar
blubyu
I think its time you get with technosquare and see if they can crack the sedan ECU and raise that rev limiter. The torque curve is nasty and the HP keeps rising and rising, with a 7k rev limit I see 350whp as an easy task. Headers and full exhaust you could probably see 370whp
