greddy tuner turbo kit (20g) question..
Old Aug 4, 2011 | 05:49 PM
350zpearl's Avatar
350zpearl
Default greddy tuner turbo kit (20g) question..
i recently purchase a brand new kit and apparently this one never came with an e-manage system not like the other greddy bolt on turbo kit. According to greddy, this kit is very customizable so it never came with one. I asked the installer locally and they said without it the car will run like crap and the idling will be unstable even after tuning it. So i'm asking for the people who have the same set up or had the experience of installing this specific kit, do i have to get an e-manage system or can i just piggy back my way around it?
thanks...
jeff
Old Aug 4, 2011 | 05:51 PM
herrschaft's Avatar
herrschaft
Just get Uprev, my car runs fine with it.
Old Aug 4, 2011 | 05:57 PM
Ruthless18x's Avatar
Ruthless18x
The e-manage is worthless, you are better off without it. If your shop doesn't understand that I would be really nervous.
Just get Osiris or a Haltech.
Old Aug 4, 2011 | 06:17 PM
hellsoldiers08's Avatar
hellsoldiers08
RUN!
Old Aug 4, 2011 | 06:19 PM
AngelsVQ's Avatar
AngelsVQ
so your shop is telling you that it will run like crap without it even with a tune.... find another shop man
350zpearl's Avatar
350zpearl
thanks for all the response guys, very helpful. I would not be driving the car that hard, maybe just be playin around 7-10 psi (for now) would i still need engine management or its a MUST have? i had boosted car before and it ran fine with out an e-manage, and i know every cars and kits are different and i just wanna make sure it runs good.
Old Aug 4, 2011 | 06:21 PM
Ruthless18x
You need an EMS. Otherwise how do you plan to compensate for the larger injectors?
You do know you need to purchase injectors with a tuner kit...right?
Old Aug 4, 2011 | 06:22 PM
350zpearl's Avatar
350zpearl
thanks for the concern with the shop lol... weird thing is they have 1 on display (haltech) for 2200 and its their last one... so hmmmmmm......
Old Aug 4, 2011 | 06:33 PM
350zpearl's Avatar
350zpearl
i have the injectors but is there anything else that i need to upgrade or get besides that i hear the oil lines from greddy's are crap as well..
Old Aug 4, 2011 | 06:38 PM
Ruthless18x
For basic stuff you need the injectors, fuel pump, gauges, wideband, ems, bov / flange, and a fuel return. Some people will probably disagree with me on the fuel return as a basic, but I believe in them.
The stock Greddy lines do suck, Forged makes a nice replacement set for about $150.
Old Aug 5, 2011 | 06:15 AM
psychoballistic's Avatar
psychoballistic
EMS is an absolute must at the very minimum. If your going to be running on stock block, you can make good power between 5-8 psi of boost.
Uprev has proven itself to be a fantastic system time and time again. That is another very feasible option for you. Depending on your location, a haltec is a very easy to use ems especially if your support is limited.
Also I ran 2yrs on a greddy system on stock block with about 14k at 8psi@430whp, all I added was my fuel pump, injectors, gauges, and BOV.
Just my .02, but this gives you an idea that depending on your needs you don't have to go all out.
Good luck with the install OP!
Old Aug 5, 2011 | 06:16 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Dont listen to these fools. The E-manage is the t!ts for tuning a VQ!
No need to even adjust timing just do A/F on the dyno and you will be good to go for many, MANY miles of boosted stock block power.
Old Aug 5, 2011 | 06:34 AM
Gingervitis526's Avatar
Gingervitis526
Just go with UpRev and call it good.
Old Aug 5, 2011 | 06:47 AM
ITOzann's Avatar
ITOzann
Lololol
Old Aug 5, 2011 | 06:52 AM
psychoballistic
Lol.......Emanage= BOOM!!!
Old Aug 5, 2011 | 06:54 AM
psychoballistic
I would agree, will make life simple for you in the long run, plus it's one less thing added in to the mix to go wrong.
Old Aug 5, 2011 | 08:14 AM
350zpearl's Avatar
350zpearl
good thing you mentioned about locations, i was advised that haltech is the only system that perfectly works up here (alberta, canada).. i would love to go for the less expensive route (uprev) but maybe with my location it won't work as well?
Old Aug 5, 2011 | 08:38 AM
psychoballistic
Correct OP, Haltec has alot of support with members here, and the software for the tuner and end user is the same. One of the big pro's to that interface for sure.
Uprev again is very strong, but your limited if you don't have an uprev dealer near you. I think a Haltec is the way to go for your situation IMHO.
Old Aug 5, 2011 | 08:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Save the money, do the E-manage, just make sure to add NOS octane booster for the timing issue. No worries, cheap, fast and reliable
Old Aug 5, 2011 | 09:53 AM
str8dum1's Avatar
str8dum1
emanage ultimate is no different than a Utec and could control the greddy kit with no problems.
it was only the original emanage that came with the old 18g that couldnt control timing.
