A little new but I have some piston and turbo Q's
Old Oct 8, 2011 | 06:05 AM
94ttz32's Avatar
94ttz32
Default A little new but I have some piston and turbo Q's
Hey guys Im new to the vq35de. Im looking to go with a set of 2860rs turbos. Im looking for 600 whp. Im wonder Can I GET by with 9;1 airs pistons or will I need something lower for this goal. My build will be simple just doing built bottom end stock cams and valves. Just your surporting mods like 3 inch exhaust and gtm manifolds! Fuel return and right size injectors of corse Im wonder what psi give or take to hit 440 for low boost and what psi give or take will hit the 600 area? Thanks in advance
Old Oct 8, 2011 | 06:52 AM
suprasam's Avatar
suprasam
Much love to the carolinas, but you gotta search. There are so many build lists/shop posts you could cookie cut your build. Research first then ask if you don't understand something. And I'm not sure a manifold is a supporting mod as much as it is a necessity (depending on the setup).
Old Oct 8, 2011 | 07:59 AM
JCITY's Avatar
JCITY
You may want to contact Momentum they are nearby in Wilmington...pretty close to you
I'd bet.Maybe take a ride over there...face to face chat on what you want to accomplish...
Old Oct 8, 2011 | 08:17 AM
94ttz32's Avatar
94ttz32
I did search on some of the things but did not find solid answers. I'm about 4-5 hours from Wilmington. I'm just trying to gather the info so I can start my build ill be assembling my engine and geting turbos fitted. I'm new to the vq35 but not new to z's I build my 300 zx it makes about 550 on 18psi with hks 2530's which are comparable. to the 2860 rs . I can't wait to feel what the z33 will feel like with same power. Well ill keep looking around for info. Thanks for yalls help so far and if you have anymore chime in please
Old Oct 8, 2011 | 08:48 AM
PB8duece's Avatar
PB8duece
600 is doable but its not going to be easy, you'll probably need cams/valve springs retainers, along with a fully built bottom end, and definitely less than 9:1 CR. I'd go with 8:5 or at the highest 8.8, it will let you push timing more. (I have a buddy with a set of forged cosworth 8:1 pistons he's selling on G35driver if you want to run as much boost as possible, PM me for details) You're going to need a full fuel return system and 800cc injectors (or something similar, the 725 Injector Dynamics are sweet) to make 600, good luck looks like you've got a lot of reading to do
Old Oct 8, 2011 | 04:41 PM
djamps's Avatar
djamps
You will need more than a walbro 255 to hit 600 wheel. Twin pumps or a bigger single.
Old Oct 8, 2011 | 05:40 PM
ace32x's Avatar
ace32x
I don't think you need cams to achieve that. Ull Def need a twin pump set up and 850 cc injectors and a manifold
Old Oct 8, 2011 | 06:01 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
You won't need cams to make over 600whp thom000001 did it with stock cams but I think he needed 30psi to do it. So they are not needed but it would be easier with them. 9.1:1 would work for that kind of power most would say 8.5:1 is better but I did it on 9.1:1 but with a 100mm bore.
Old Oct 8, 2011 | 06:22 PM
phunk's Avatar
phunk
CJ Motorsports
9:1 is fine, no reason to go any lower.
Old Oct 9, 2011 | 04:01 PM
str8dum1's Avatar
str8dum1
I'm running 9:1 pistons as well. stringing out a car on pump gas isnt a good idea to begin with and an extra 0.5 in compression wont make that much difference
Old Oct 10, 2011 | 07:48 PM
94ttz32's Avatar
94ttz32
Thanks for the new Info.
Does anywone have any idea on what psi I should try to get the car around 440whp for the low boost setting on my internal wastegate. GT2860rs twins
Old Oct 10, 2011 | 08:12 PM
ace32x's Avatar
ace32x
Old Oct 11, 2011 | 03:52 AM
rh_334's Avatar
rh_334
Why GT2860rs? Why not GT2871s like a lot of the kits for our platform. I think the 60 is going to make it difficult to break 6's. I have 2871s with .86hot side, larger compressor side and custom piping, i made 620rwhp+ on pump. While a stock APS car (basically same built block) with smaller .63 hot side and tiny compressor housing only makes ~570rwhp on pump (which I still think would outperform GT2860s)
Originally Posted by ace32x
5-8
It might take more than you would think being a low comp motor with tiny turbos, im thinking 10ish.
Old Oct 11, 2011 | 06:48 AM
str8dum1's Avatar
str8dum1
do you have a dyno sheet of the 620+ on pump with those turbos? be interesting to see their powerband.
Old Oct 11, 2011 | 06:53 AM
binder's Avatar
binder
that is impossible to determine. every car is different, every dyno is different. Boost numbers are only a number. Tune to hp/tq and forget what boost it is.
I laugh at people that ask "what boost is your car running". Like they would know how each psi for my engine, with my turbo, housing, heads, etc would react. Small turbo on 19psi is far less power than a large turbo at 10psi due to flow. Same turbo with a larger housing will produce more power with less boost pressure as well. Boost pressure is so relative that it's pointless to even talk about it.
also, compression ratio is relative to your build as well. There are plenty of cars with high compression boosted motors. It depends on many things in your setup with octane being the highest. You won't necessarily make more power on 8:1 pistons with more boost than you would with 9:1 compression with less boost. You need more octane for higher compression and generally for the same power output will run lower boost pressure.
For pumpgas you really won't notice a difference from 8.5-9.5 that is offered for our cars so just pick the pistons based on what the engine builder recommends, your power goals, and your budget.
Old Oct 11, 2011 | 07:05 AM
rh_334's Avatar
rh_334
Its actually still on the dyno, and im working on a thread. But once we finish up ill pm you a graph.
Old Oct 11, 2011 | 07:32 AM
str8dum1's Avatar
str8dum1
good deal, good luck!
Old Oct 11, 2011 | 08:31 AM
94ttz32's Avatar
94ttz32
Oh I understand everything your saying Im not new to FI. I was just wondering where i should start with my internal setting to get me close that I would not set it to 14 psi (JUST THINGKING THATS WHERE I NEED TO BE)and be way over my tarket HP for for street driving.
Old Oct 11, 2011 | 08:39 AM
94ttz32's Avatar
94ttz32
I was thinking of the gt2871 But was not sure How they would work on the vq They are shitty on the vg30dett They are real laggy and power band is not that fat! Im looking for something That would maybe make 650whp after cams and some other mods!. Im looking for full boost by 3400-3800 rpms. I have a 700 hp Vgdett now I have hks 2530 (Aka modded 2860rs) So I was hoping that the 2860 would were well with the vq Maybe spool a little fast than my vg which gets full boost at 3800 And will lay 700whp.
TELL me which way you would go and why or more info oh how the 2871 work for you spool time and such etc
Thanks
Old Oct 11, 2011 | 09:21 AM
ace32x's Avatar
ace32x
Thanks
The 2871's with the .86 ar will get u to mid 600s low 700s if u have the supporting build. On my stock block set up (3.5L hr) I was seeing full spool by 4k. And pulled all the way to 8k. Went to a bc 4.07L low comp set up now hoping to see full spool around 3600-3700 Def a good turbo for vq imo
