Please help!!! Car overheating
Old Oct 11, 2011 | 09:43 AM
krivera6950's Avatar
krivera6950
Originally Posted by Sharif@Forged
Those little pieces of gasket in your coolant are likely head gasket material. coolant should not spew and overflow/overheat under boost. It's normal to see a rise in coolant level but not overheating and severe overflowing.
I'd check your headgasket, after doing a thorough purging of the cooling system. Best of luck.
After purging the system earlier this morning, I didn't get any further residue of RTV or gasket material, i bled out the system through the bleeder on the rear hot pipe several times. after i finished I let the car idle for about 10 mins then drove the car for about 30 minutes with a mix of cruising and under boost. Car didn't overheat at all. coolant level dropped a tiny bit in the reservoir but that's it. car drove fine in both cruising and under load. Is it still possible that there may be something wrong with the head gasket?
Old Oct 11, 2011 | 09:46 AM
djamps's Avatar
djamps
Only time will tell. Keep an eye on the overflow tank over the next week or so and top it off as needed, you may notice it keeps going lower over the next days as small pockets of air slowly purge out.
Old Oct 11, 2011 | 10:22 AM
krivera6950
Good to know, after letting the car cool off, the overflow tank went from almost completely full to about 2/3 full.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
