844whp@26.5psi
Old Oct 20, 2011 | 08:44 AM
  #81
ace32x's Avatar
ace32x
Originally Posted by meatbag
Just depends on what you are doing with the car. People like Fontana have to abide by Grand Am rules so they make power NA by revving higher. People drag racing on serious setups need the extra rev range to spool bigger turbos and hold gears longer, etc... Everyone does what they need to do to make power with what they are using the car for.
The find the one setup that works in a stock rev limit and makes the most power mentality cant really be applied to everyone.
^ for a street car i dont see a need to rev that high. for a huge power hunt and dyno queen sure why not but where the f@wk u gonna drive a car that makes 1k + whp up at say 5k rpm? thats not streetable at all lol will just burn the tires unless your running slicks or something lol. seems 800 whp is pretty achieveable with vqs, and looking at the HR and the VHR the heads flow pretty damn good from the factory and rev out to 8k with stock cams. 2 30 series turbo or say a 20g's + the newer vqs will get up into the 800+ area pretty easily it seems and the blocks seem to hold up a bit better aswell than the older DE's and rev up's. Seems to me once more shops get familiar with thr HR and VHR you will see alot bigger builds than on the DE and rev up
Old Oct 20, 2011 | 09:26 AM
  #82
meatbag's Avatar
meatbag
Maybe im missing it, but the original argument was about the VQ35DE not being up to snuff for high rpm high power use which has been disproven not weather or not high power is useful for the street. Essentially look at any race team and youll see a high revving motor for whatever reason.
Hopefully this thread can get back on topic.
Old Oct 20, 2011 | 09:44 AM
  #83
str8dum1's Avatar
str8dum1
ya, go get your cam logs
Old Oct 20, 2011 | 12:04 PM
  #84
ace32x's Avatar
ace32x
i guess i missed it lol my mistake. i was under the impression we were discussing the vq as a whole lol.
Old Oct 20, 2011 | 02:55 PM
  #85
binder's Avatar
binder
Originally Posted by nyqueenz
OP do you keep the c16 in the tank for a peroid of time.. I heard that its not good for the seals on the injectors..
you are thinking q16. oxygenated fuels are hard on seals and VP fuels c series is non-oxygenated. I've been running c16 in bikes since i was 10 years old and in 4 cylinder fuel injected race bikes for 10 years. Not once have I had nor have i heard of anyone having seal issues due to a non-oxygenated fuel.
Old Oct 20, 2011 | 03:26 PM
  #86
Resmarted's Avatar
Resmarted
Yeah I feel bad about the thread jack, but these are pretty pertinent discussions that I think are in the back of all our minds, ya know?
The basic argument is that to make more power you need to push more air. To push more air you need bigger turbos which means either increasing displacement or increasing the rev limiter (pointless to make 1300hp for like 800rpm). The 3.5 liters is PLENTY, actually imo almost a perfect amount, but the motor just can't rev that high.
Would it be appropriate to open another thread and continue there?
Old Oct 20, 2011 | 04:28 PM
  #87
eat rice z33's Avatar
eat rice z33
All hail meatbag! no seriously.... your the man
Old Oct 20, 2011 | 04:50 PM
  #88
meatbag's Avatar
meatbag
I dont mind discussion as it is a point I alluded too. I just didnt want it to get watered down with statements of what everyone needs to run and how hard or not hard my car is driven.
I have a Nismo oil pump in my motor now and there is no difference between it and a revup oil pump that I can see.....except the inner gear on the pump. The edges are rounded around the flat planes that is uses to key itself to the crank. I will try to dig up the pictures I took. Every VQ oil pump that I have seen fail has done so at those corners so maybe this helps to keep the metal from tearing apart at that point which has the largest load on it.
Old Oct 20, 2011 | 04:52 PM
  #89
Resmarted's Avatar
Resmarted
I'm pretty sure injectedperf/dynosty sated that the rev up and the nismo pumps are pretty much the same.
You wouldn't happen to have your rev up pump still? I think I want to get one... (should have bought it from blackbird when I had the chance smh).
Old Oct 20, 2011 | 05:04 PM
  #90
Old School's Avatar
Old School
Shift_Boost
Nice one B.
Old Oct 21, 2011 | 05:58 AM
  #91
str8dum1's Avatar
str8dum1
they are like 150$, i'd never buy a used pump
Old Oct 21, 2011 | 06:44 AM
  #92
Resmarted's Avatar
Resmarted
lol... i know i shouldn't buy a used pump... and i know they are like 170 but...
now i look super cheap hahahaha
Old Oct 21, 2011 | 09:30 AM
  #93
str8dum1's Avatar
str8dum1
esp considering how ironic this is based on your signature
Old Oct 21, 2011 | 09:48 AM
  #94
ace32x's Avatar
ace32x
Old Oct 21, 2011 | 10:09 AM
  #95
thawk408's Avatar
thawk408
meatbag,
Do you have a boost graph that goes along with the 844 run? I'd like to see how the turbos are holding at that boost level.
Old Oct 21, 2011 | 10:20 AM
  #96
meatbag's Avatar
meatbag
Originally Posted by thawk408
meatbag,
I blew this one up so you could see it better.
Old Oct 21, 2011 | 10:24 AM
  #97
meatbag's Avatar
meatbag
Here are the last couple runs so no one thinks it was a hero pull.
Old Oct 21, 2011 | 05:29 PM
  #98
Resmarted's Avatar
Resmarted
fixed
Old Oct 21, 2011 | 05:41 PM
  #99
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
^^ Nice consistency on those dyno runs.
Old Oct 21, 2011 | 07:51 PM
  #100
meatbag's Avatar
meatbag
Snapped the inner cv on the first run tonight so no data logs till I get some new ones.
