exhaust leak?
Old Nov 18, 2011 | 05:59 AM
winNvegas's Avatar
winNvegas
Default exhaust leak?
I was just wondering if its normal for the inside of a FI car to smell like exhaust fumes or is it more likely i have an exhaust leak. I've tightened all my bolts and clamps but it didnt help. My car has no cat by the way. If i roll up the windows and recirculate the air, the smell disappears. Thanks for input.
Old Nov 18, 2011 | 06:17 AM
Cass007's Avatar
Cass007
Do you still have cats? If its an exhaust leak you should hear a tapping sound when cold that may go away or diminish as the car heats up.
What F/I setup do you have? Some have been known to crack at the manifolds.
Old Nov 18, 2011 | 06:21 AM
djamps's Avatar
djamps
Probably a leak up front near the downpipes or manifolds. Could also be a fuel leak.. The 'outside air' is drawn from the engine bay basically. I had a pinhole leak on a weld on a gasket that I couldn't hear that I could smell.
Old Nov 18, 2011 | 07:06 AM
f150intally's Avatar
f150intally
every FI car I have ever owned with straight through exhaust (no cats) has smelled the same (exhaust fumes). Make sure you recirculate air in the cabin when driving with the windows up. Otherwise, get used to it.
Old Nov 18, 2011 | 07:37 AM
binder's Avatar
binder
ya, how is your catch can setup? open breather type catch cans that vent into the engine bay will allow engine fumes to be drawn into the vent system. Doesn't have to be exhaust leaking to cause this.
Old Nov 21, 2011 | 05:56 AM
winNvegas's Avatar
winNvegas
I have the turbonetics setup, which I installed myself so Im expecting some minor mistakes. Yes, I do have open breather as well as no cat, so I'll guess that its a combination of everything you guys mentioned! Me = No cat, self install (possible leak), "worst on the market FI kit", and open breather system. I guess I'll just live with it for now. Thanks guys.
sales@czp
Sep 23, 2019 03:30 PM
Twenty4
Jan 17, 2016 01:20 PM
Justin100
Nov 29, 2015 03:58 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Li1ag
Sep 28, 2015 02:07 PM
