Retune @R/T Tuning, dyno + track slip inside
Old Nov 21, 2011 | 07:00 AM
djamps's Avatar
djamps
Default Retune @R/T Tuning, dyno + track slip inside
So I drove up to PA and let vince work his magic for a couple hours last Thursday. He was the only 'local' tuner that was fine working with my existing self-made street tune and let me leave with an unlocked ROM. Previous tune netted 12.6@111mph. New tune 11.9@119mph. Big thanks goes to Vince for going the extra mile battling my hyper-active turbos. .
Before (my own street tune) and after overlay attached.
Attached Thumbnails Retune @R/T Tuning, dyno + track slip inside-rttuning-dyno.jpg   Retune @R/T Tuning, dyno + track slip inside-cecil-timeslip.jpg
Old Nov 21, 2011 | 07:31 AM
thatv35guy's Avatar
thatv35guy
Nice times!
What’s your track setup (tire, suspension, weight, etc.)?
If that dyno is displaying the before and after the tune, that’s a whole lot of trap to pickup from an additional 15 whp and 10 lbs. of torque!
I suck if I don’t break 11’s now! Lol…
Old Nov 21, 2011 | 07:53 AM
djamps's Avatar
djamps
Originally Posted by thatv35guy
Nice times!
ran a splash of race gas + no knock control by recommendation of Vince... long story short there is phantom knock all over the place as you can see on the graphs. I guess it made a pretty big difference D/A of -500ft surely helped as well...
full weight + tools and subwoofer. 26x11.5x16 Et Streets, 350Z S-techs, stock shocks.
Old Nov 21, 2011 | 09:13 AM
350zion's Avatar
350zion
Professional
Congrats man,, time slip looking real good!
Old Nov 21, 2011 | 10:37 AM
str8dum1's Avatar
str8dum1
what boost controller are you using? Did he adjust timing or wastegate duty cycle to get the turbos to spool faster? -500 is a great DA.
Old Nov 21, 2011 | 10:56 AM
djamps's Avatar
djamps
HKS EVC6. Vince messed with the settings a little but I didn't pay attention to what he changed. He added timing and cam advance down low which helped the spool. I'm now running 22-23 deg by redline (instead of 18). Apparently small TT setups like more timing up top than I thought.
Old Nov 21, 2011 | 12:09 PM
str8dum1's Avatar
str8dum1
big setups like timing up top as well. you just need the octane to do it.
Old Nov 22, 2011 | 08:56 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
glad ya made the trip up. Also nice when the car comes in with a good base map and allows us to fine tune and really dial in the ROM.....
Old Nov 23, 2011 | 05:55 AM
djamps's Avatar
djamps
Thanks vince It was a pleasure...
for anyone who hasn't been to R/T before I will say they probably have the biggest shop I've seen, not to mention two dynos (dynojet 2WD and mustang AWD). deceptive from the outside...this place is legit.
Old Dec 1, 2011 | 09:42 AM
Erik@R/Ttuning's Avatar
Erik@R/Ttuning
Sorry I had to leave before I got to see the final pulls. Looks like everything really came together!
It was good to have you guys at the shop for the day.
Old May 8, 2012 | 02:39 AM
Jime's Avatar
Jime
djamps do you have any traction issues with the ET Streets or do they dead hook? Just wondering if a shorter slick would hold traction ie 24x8x15.
Old May 8, 2012 | 05:52 AM
Alberto's Avatar
Alberto
Cranky FI Owner
There are 8 second cars on a 10.5" Chester slicks. They will hold.
24" would put you well into 5th on a quick car and you want to avoid that shift if possible IMO.
Old May 8, 2012 | 07:05 AM
djamps's Avatar
djamps
No traction issues at all. It will either dead hook or slip a little (controlled) depending on track prep, tire pressure and burnout intensity. Sometimes I don't have to burnout at all.
Old May 8, 2012 | 03:47 PM
Jime's Avatar
Jime
Don't think that would happen. Even at 6500 4th gear will do 125mph at 7000 4th will net 135mph so 5th just won't happen.
Not sure your definition of QUICK but I netted a 10.85 @ 125 mpg on my Maxima and if I can get my G to do that I would consider it quick.
QUICK means different things for different people. For my purposes I only need to run 11.99 or quicker to run my race class. All of the guys in that class trailer their cars whereas I drive mine. I am a racer. Those who only go to the track to get a better time or T&T to try their cars hold no interest for me.
Old May 9, 2012 | 11:20 AM
binder's Avatar
binder
You are in the 350z forum. You said 24" tires which are 2" smaller in diameter than the stock tire size for the 350z. The transmission isn't the same as the maxima so 24" tires might get you only into 4th with the maxima but on a Z you will probably be in 5th if you run that small diameter tire. Most guys run 26 or 28" tall tires on the 350z/g35 to avoid having to shift at the end of the 1/4.
Old May 9, 2012 | 12:09 PM
djamps's Avatar
djamps
With my 26" tires I hit 120mph at 7krpm in 4th right as I cross the line. With a smaller tire, un-raised redline, or a faster car and I'd have to go to 5th.
Old May 9, 2012 | 12:21 PM
Jime's Avatar
Jime
I do own a G35 and those figures are using the FSM for ratios (which are the same for a 350Z) and a 3.69 rear which I plan on installing.
I believe the discrepancy is that I am referring to an auto not a manual. Drag racers have long given up on manual transmissions. An auto is much more consistent than a manual so racers have all gone that route. Not sure how the Z world is doing auto vs manual but my Maxima is almost 3/4 of a second faster than the closest manual in the 1/4 and a 1.58 60' vs a 1.7x for the manual and thats FWD.
Old May 9, 2012 | 12:33 PM
djamps's Avatar
djamps
At least on a G35, there's no way a 5AT will be consistently faster than a 6MT given all things equal including adequate traction, unless (as Alberto would say) the 6MT driver is suffering from palsy.
Old May 9, 2012 | 01:12 PM
Jime's Avatar
Jime
Drag racing is all about consistency not faster or quicker. Heads up racing is all but dead except at the top pro levels which no one here does. Bracket racing takes much more skill and a super consistent car to be a winner.
PS There are a LOT of drivers with Palsy.
Old May 9, 2012 | 01:13 PM
athenG's Avatar
athenG
where did you get these #'s?
Binder is right... tire diameter + gear ratio matters.. even at with the 26 you will end up on 5th gear if you go past 120mh...
Code:
26.3 Tire Diameter
RPM	1st Gear	2nd Gear	3rd Gear	4th Gear	5th Gear
500	3	5	7	9	11
600	3	6	8	10	13
700	4	7	10	12	15
800	5	8	11	14	18
900	5	9	12	16	20
1000	6	10	14	17	22
1100	6	10	15	19	24
1200	7	11	16	21	27
1300	8	12	18	23	29
1400	8	13	19	24	31
1500	9	14	20	26	33
1600	9	15	22	28	35
1700	10	16	23	30	38
1800	10	17	25	31	40
1900	11	18	26	33	42
2000	12	19	27	35	44
2100	12	20	29	37	46
2200	13	21	30	38	49
2300	13	22	31	40	51
2400	14	23	33	42	53
2500	15	24	34	44	55
2600	15	25	35	45	57
2700	16	26	37	47	60
2800	16	27	38	49	62
2900	17	28	40	50	64
3000	17	29	41	52	66
3100	18	29	42	54	69
3200	19	30	44	56	71
3300	19	31	45	57	73
3400	20	32	46	59	75
3500	20	33	48	61	77
3600	21	34	49	63	80
3700	22	35	50	64	82
3800	22	36	52	66	84
3900	23	37	53	68	86
4000	23	38	55	70	88
4100	24	39	56	71	91
4200	24	40	57	73	93
4300	25	41	59	75	95
4400	26	42	60	77	97
4500	26	43	61	78	99
4600	27	44	63	80	102
4700	27	45	64	82	104
4800	28	46	65	84	106
4900	29	47	67	85	108
5000	29	48	68	87	111
5100	30	49	70	89	113
5200	30	49	71	90	115
5300	31	50	72	92	117
5400	31	51	74	94	119
5500	32	52	75	96	122
5600	33	53	76	97	124
5700	33	54	78	99	126
5800	34	55	79	101	128
5900	34	56	80	103	130
6000	35	57	82	104	133
6100	36	58	83	106	135
6200	36	59	85	108	137
6300	37	60	86	110	139
6400	37	61	87	111	141
6500	38	62	89	113	144
6600	38	63	90	115	146
6700	39	64	91	117	148
6800	40	65	93	118	150
6900	40	66	94	120	153
7000	41	67	96	122	155
