Missing MAIN HARNESS FOR HKS AFK KNOCK AMP version 1
Old Nov 28, 2011 | 11:40 AM
De La Money's Avatar
De La Money
Default Missing MAIN HARNESS FOR HKS AFK KNOCK AMP version 1
as title says, here a pic of said part. let me know where i can get one if somebody has one. Vendors?sponsors im paypal ready. thanks
Old Nov 28, 2011 | 07:33 PM
meatbag's Avatar
meatbag
HKS has never been really good about selling individual harnesses. You will probly have to find another unit and use the harness from that.
Old Nov 29, 2011 | 05:19 AM
djamps's Avatar
djamps
Plus isn't HKS pretty much done for in the USA? Good luck getting any parts from them...
Old Nov 29, 2011 | 07:26 PM
De La Money
VENDORS/SPONSORS/ OG FI Heads PLEASE HELPPPPPPPPPPPPPPPPP.
Old Nov 30, 2011 | 02:39 PM
suprasam's Avatar
suprasam
have you tried Forged Performance in Marietta? They sourced me a secondary O2 sensor after HKS USA closed.
Old Dec 2, 2011 | 07:13 PM
De La Money
i did, but i they said they didnt have it in stock nor could they Probably get one hks. did they get yours for the same version knock amp as me?
Old Dec 3, 2011 | 11:09 AM
phunk's Avatar
phunk
CJ Motorsports
i know this sounds really ghetto... but if you find a crimp on female terminal of the proper size to slide onto the male terminals inside that connector, you can make a little harness with just the wires that you need, then fill the connector with epoxy so that they dont slide off or move around and contact each other.
it works, i know for sure. because a friend gave me a knock amp missing the same exact harness. so i had to do that. even though i ended up throwing the whole unit away a week later because the backlight in the display was super dim (different connector, dont blame me lol)
Old Dec 3, 2011 | 03:19 PM
De La Money
okay, where did you get all the parts to supplement the harness, connect to the fcon, and the my 02 sensor????
Old Dec 3, 2011 | 06:26 PM
phunk's Avatar
phunk
CJ Motorsports
Even when I had the whole harness setup in my 350z, I spliced the knock amp into the fcon harness and tossed out the connectors. When I put the one without a harness in my 370, my 370 doesn't have the fcon but its all the same just wire up the output to the input and use any crimp on connector you want for easy disconnect... Spade or bullet style whatever you want.
That older version knock amp you have uses an older NTK wide and sensor which I have never seen available with the original connector that the knock amp used. Meaning you had to cut off the plug anyway unless using the original sensor that came with the knock amp, which would be really old by now. These ends of the harness are just basic wire connections you can handle this
Old Dec 3, 2011 | 06:34 PM
phunk's Avatar
phunk
CJ Motorsports
Oh here ya go, here's a place listing the same NTK sensor that came with that knock amp and the same connector;
http://www.bmotorsports.com/shop/pro...roducts_id/438
They have this page of all sorts of wideband connectors
http://www.bmotorsports.com/shop/ind.../cPath/103_108
But I'm not seeing the other end to match that NTK. Perhaps just use connectors from another sensor .. Doesn't really matter
HoBrahYouStink
Jun 24, 2016 10:58 PM
