How's my build?
Old Jan 5, 2012 | 04:15 PM
ctadashi09's Avatar
ctadashi09
Default How's my build?
Im going to be doing a supercharger build on my 03 DE 350z and was wondering if i could get some input about my build? If you guys can think of better parts or parts i should replace please tell me. This is my daily driver and I am only looking to get about 400 whp out of this setup for now.
  • Vortech V3 Supercharger kit
  • Limited Edition Gold Mishimoto Intercooler
  • 570cc injectors
  • Upgraded Impeller
  • Meth Injection Kit
  • Osiris UpRev Tune
  • Walbro 255LPH fuel pump
Im getting this done at a shop. Please Point out if I have forgotten to list anything Important.
Old Jan 5, 2012 | 04:32 PM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
One step colder plugs and an UPREV GT MAF. We stock pretty much anything you would need for your set up. let me know if you are interested.
Old Jan 5, 2012 | 05:44 PM
Eno's Avatar
Eno
Looking through the spec sheet there are both manual and auto versions of the 03 350z with the DE... Typically guys going this direction look at clutch upgrades? Or are you an AT?
Old Jan 5, 2012 | 06:04 PM
ctadashi09's Avatar
ctadashi09
AT. and yes im probably going to get flamed for this but as a college student that commutes in traffic. Its more convenient.
Old Jan 5, 2012 | 06:15 PM
Eno's Avatar
Eno
Meh... just means your transmission upgrades are more expensive. 95% of daily drivers with MTs WISH they had ATs... for the 5% of the time I'm wishing I had an MT I'd call it a reasonable sacrifice.
I would look into the transgo shift kit- though it won't help your transmission endure the extra abuse of higher torque shifting it will clean things up and add a whole new level of enjoyment to your FI upgrade. Not cheap... but well worth it if you're leaving the auto transmission stock.
If I had a choice between water meth and transgo... for your conservative build "aspirations" I'd definitely put the money in the transgo. I'm just not sure that you're going to take your build far enough to benefit from it? Overkill maybe for a daily driver? Wanting a little cavalry under the pedal to make the commute more exciting doesn't require a tuner to push things so far as to need the W/M system. Sorry- just sounds a little overkillish to me.
Some of the heavyweights in here may also shed some light on whether or not w/m is as beneficial on SCs versus turbos...
Old Jan 5, 2012 | 06:16 PM
unvmyg35's Avatar
unvmyg35
Is this on a stock block? The upgraded impeller and 2.87 pulley might be to much for the stock block.
Old Jan 5, 2012 | 06:28 PM
ctadashi09's Avatar
ctadashi09
correction* sorry the impeller was just replaced. and its the stock V3 vortech kit. no 2.87 pulley. I should be fine on a stock block if i run it on the lowest boost and on stock settings right?
Old Jan 5, 2012 | 07:50 PM
graffkid732's Avatar
graffkid732
Search. There are a ton of stock block SC builds.
Old Jan 5, 2012 | 08:21 PM
ctadashi09's Avatar
ctadashi09
Original question is how is my build. not others
Old Jan 5, 2012 | 08:31 PM
Eno's Avatar
Eno
Well- the search feature DOES work and will work to identify the capabilities of a stock block. Everyone will generally meander around 400hp / tq and about 6-8 psi on the DE.
Also, the SHOP doing the install should be pointing you in the right direction. Once you get their input you can lay it in here and guys will be able to tell you if they're just taking you for a ride. Some shops will build anything you tell them... others will make sure they keep you down on solid ground.
But you're not going to get too much more feedback in here until there's some evidence of a commitment to the transition that makes this different than a "I'm thinking of going FI... how do you like this parts list?" Once that transition occurs then I suspect information may be more forthcoming.
Old Jan 5, 2012 | 08:42 PM
ctadashi09's Avatar
ctadashi09
Oh i already have all the parts and putting them in most likely next week. Just didnt know if i was missing anything or needed better parts. If my parts list was ok
Old Jan 5, 2012 | 09:39 PM
Eno's Avatar
Eno
What does the shop say?
Old Jan 5, 2012 | 09:41 PM
ctadashi09's Avatar
ctadashi09
honestly they said it was fine. but it isnt like a huge famous performance shop so i thought id get my peers opinions...ill post the dynos and how everything went when its all installed and tuned
Old Jan 6, 2012 | 06:25 AM
str8dum1's Avatar
str8dum1
dont waste your money on the meth kit.
Old Jan 6, 2012 | 06:31 AM
djamps's Avatar
djamps
Change: Reduce whp goals to 360-370whp
add (in order of importance): spare vehicle, transmission cooler, transgo valvebody kit, gauges, 3-4k in the bank for a used junkyard motor or trans when it pops
Remove: meth kit
Regardless, your shop is retarded if they think you're going to put down that kind of power reliably without 5AT valve body upgrades.
Old Jan 6, 2012 | 12:03 PM
ctadashi09's Avatar
ctadashi09
Meth kit was free. Might sell it and get the valve body upgrade
Old Jan 6, 2012 | 12:36 PM
zach711f's Avatar
zach711f
Remove: meth kit
I would def put gauges before anything else in that list..just saying. at least a AFR and boost gauge.
Old Jan 6, 2012 | 12:54 PM
Eno's Avatar
Eno
Yeah if that shop was happy just putting in that stuff you listed the first thing I would be doing is looking for another shop. I have first hand experience (for once) on what happens when shops that aren't familiar with our platform go to work on boost applications with the VQ and the results were Abysmal.
The mention of the tranny cooler is extremely fitting for the AT- regardless. Heat kills our transmissions- with or without aftermarket boost. That is a relatively cheep add on. Transgo (installation) is a bit pricey and you may want a specialized transmission outfit to install it. That's how I did it, anyway.
Spare vehicle goes without saying and extra "go to" cash if things go south or for that timely upgrade of a supporting mod (wider wheels, better rubber, oil cooler... Whatever).
Who is going to tune the Osiris?
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
