View Poll Results: Where do you guys pull your motor from?
From the top of the motor with a hoist.
50.00%
From the bottom dropping the sub-frame.
50.00%
Voters: 12. You may not vote on this poll
Quick question on pulling the engine
Old Jan 9, 2012 | 09:37 AM
psychoballistic's Avatar
psychoballistic
Default Quick question on pulling the engine
I've now pulled the motor twice. Once from the top straight out and the other from the bottom dropping the sub-frame and all. Looking to see what is more common and what people find easier. I have seen a mix in other threads, but trying to bring it to one common spot.
Old Jan 9, 2012 | 09:46 AM
djamps's Avatar
djamps
Front or bottom is most common for twin turbo because you can't come out the top with the turbos installed. Dropping the engine w/subframe attached seems by far the best way if u have access to a lift. Otherwise out the top for N/A if u have an engine 'crane' or whatever they call it is pretty straight forward as well.
Old Jan 9, 2012 | 10:03 AM
psychoballistic
I did the subframe with turbos last winter and was thinking about doing it through the top again like the first time. I'm honestly just undecided.
Old Jan 9, 2012 | 10:15 AM
tonyzS/C03's Avatar
tonyzS/C03
If you have access to a lift, out the bottom is by far the easiest, other wise i just pulled mine out through the front in my garage with a crain/hoist. and that only took me about 4 or 5 hours of slow and steady work...
Old Jan 9, 2012 | 10:20 AM
ace32x's Avatar
ace32x
i just did one out the front and it wasn't to bad at all
Old Jan 9, 2012 | 10:48 AM
str8dum1's Avatar
str8dum1
i wish i coulda dropped the car onto the motor. That way I coulda had everything bolted to the motor.
i've pulled it out the front every time though.
If you have a lift, then out the bottom is easiest.
Old Jan 9, 2012 | 10:58 AM
nathanwl2004's Avatar
nathanwl2004
We did mine out the bottom on a lift. But i would think out the front wouldn't be too bad either. I preffer the bottom though.
Old Jan 9, 2012 | 11:44 AM
08NismoZ's Avatar
08NismoZ
With the Greddy kit I just pulled the motor right out the front with everything still attached. We had to unbolt the steering shaft from the steering rack to make room for the drivers side down pipe though.
Old Jan 9, 2012 | 11:59 AM
psychoballistic
I had to do that too going out the top, and pretty sure I did it going out the bottom too. First time I forgot to mark the spline and had to re-align the rack
Old Jan 9, 2012 | 06:22 PM
Cass007's Avatar
Cass007
I've done it a few times now. Drop everything (engine and trans) down just enough to clear the cross member bolts, then pull it out through the front.
Old Jan 10, 2012 | 05:37 AM
Ruthless18x's Avatar
Ruthless18x
Agree 100%. I'll admit the first time was a nightmare, probably because I was so cautious, but now it's really not a big deal at all.
Old Jan 10, 2012 | 05:54 AM
Glex25's Avatar
Glex25
I had my turbos installed and piping and put the motor back in over the top.
I scratched the engine bay a bit but definitely do able
I had my motor pulled 3x twice out the front and the last one I did over the top with the turbos.
I would rather do it from the bottom if I could
Old Jan 13, 2012 | 07:16 AM
psychoballistic
Seems like alot of guys still go out the bottom... I've done both, but was curious what most prefer. I Like the idea of not having to remove everything in the car to go out the bottom, especially since the primary pull is for changing oil pump, sprockets, and manifold. The turbo upgrade is just going to be a bonus Thanks for the input everyone!
Old Jan 14, 2012 | 03:25 PM
binder's Avatar
binder
3rd option which is the easiest: straight out the front. Don't even need to break apart the a/c lines. I just moved the condenser off to the side and left the a/c sealed.
Old Jan 14, 2012 | 06:19 PM
str8dum1's Avatar
str8dum1
ya i always removed the radiator and core support. never even occurred to me to even try to pull the motor with that there.
etkms
Jun 19, 2022 06:30 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
reno56
Cooling System
Sep 19, 2015 11:34 AM
RyansZ33
Sep 15, 2015 05:54 AM
NYGiants0186
Sep 8, 2015 10:37 AM
