Engine parts needed to support boost.
Old Aug 29, 2012 | 08:27 AM
  #41
SexyRob's Avatar
SexyRob
seen too many rods bend and holes in the block because of people who thought their stock block would hold 400 easy..
IMO I look at it like this... The stock block was designed to hold the 220 whp that it puts out. This is probably about 50-60% capacity of the design, the reason for this is because the nissan doesn't want to be replacing engines all the time. As you increase the HP/TQ you start raising that %.. by the time you are at 400 whp you are running close to 100% of the capacity of the stock block. Yes it will probably run for a bit but you never want to run maxed out, there is no room for error. Building the block brings that % back down and lets you run reliable power in that range.
either way, oil cooler is a must. Don't think anyone can argue that. I think they should come on the stock block actually. Maybe I just say that because I live in texas and its over 100f most of the year.
Old Aug 29, 2012 | 12:42 PM
  #42
Nismo350z#0310's Avatar
Nismo350z#0310
Thank you, SexyRob, for affirming my input on the oil cooler.
Old Aug 29, 2012 | 01:45 PM
  #43
SexyRob's Avatar
SexyRob
FWIW I monitored oil temps before I put a cooler on and they routinely got up to 240-250f
after I installed a 19 row cooler and -10 AN lines it never gets above 210F
oh another thing, the before temp was when I was NA the after temp was when I was FI.. so more power and still way lower temp.
Old Aug 29, 2012 | 08:41 PM
  #44
midz350's Avatar
midz350
I don't think a built VQ is any more reliable than a stock one. Too many things can go wrong in a built VQ specially main bearings.
Sometimes I wish I just got a stock shortblock and kept it around 400-450whp and called it a day instead of three $$$ built engine.
Old Aug 29, 2012 | 09:48 PM
  #45
SexyRob's Avatar
SexyRob
sounds like a problem with the engine builder.. I don't know your situation but built blocks shouldn't be trashed so easily.
Old Aug 29, 2012 | 10:11 PM
  #46
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Exactly.
Old Aug 30, 2012 | 09:39 AM
  #47
midz350's Avatar
midz350
I have seen blown built engines from most of the engine builders in this forum.
People are swapping the VQ for a reason.
Nissan engines are known for the "spun bearing" problem. I know a lot of Skyline R32-34 GTR owners swapping the RB26DETT with 2JZGTE engine .
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 27, 2015 03:21 PM
