Procharger - 1st oil change?
Old Dec 26, 2003 | 01:18 AM
swinke's Avatar
swinke
Default Procharger - 1st oil change?
I just did the first oil change on my Procharger. The oil used is the oil that came with the kit from ATI. I had 600 miles on the oil. As required by ATI I did the first change. The oil was thin as vodka and had a very grey (metal particle saturated) look to it. The magnetic drain plug was completly grey with fine, dust sized metal particles. Is this normal on a first oil change?
Old Dec 26, 2003 | 01:22 AM
elektrik_juggernaut's Avatar
elektrik_juggernaut
Thats how mine was.....just like that
Old Dec 26, 2003 | 04:26 AM
Black LS1 T/A's Avatar
Black LS1 T/A
The first oil change is a break-in period. During a break-in, fine particles from the initial wear may be in the oil. This is why they tell you to change it after the first 500 miles when you start using it.
Old Dec 26, 2003 | 04:46 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Here's my thread with pics of my first oil change back in September.
https://my350z.com/forum/showthread....ger+oil+change
Old Dec 26, 2003 | 10:03 AM
Eagle1's Avatar
Eagle1
Default Procharger oil change.
Very normal. Mine was the same.
Old Dec 26, 2003 | 11:04 AM
swinke's Avatar
swinke
Most appreciated. Thought it was a little strange. Hope the next change looks better than this first one.
Old Dec 26, 2003 | 12:40 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I did the second one at about 1000 miles (on the Procharger) and while the oil still had that silvery color, there were no metal flecks whatsoever.
Old Dec 26, 2003 | 08:38 PM
swinke's Avatar
swinke
It seemed to me that taking off the driver side wheel and front inner fender shield was the easiest access to the drain plug on the head unit. I already had the Z on jack stands to change the engine oil so taking off the wheel was simple at that point. I still can’t believe the "vodka like" consistency of the SC oil they give you from ATI. It’s like -20 SAE or something.
Old Dec 27, 2003 | 02:57 AM
12SecZ's Avatar
12SecZ
They sell a ten dollar tool to remove the oil next time
might as well bite the bullet and order one. Time is money!
Old Dec 27, 2003 | 07:40 AM
Eagle1's Avatar
Eagle1
Default Oil Syringe
I have the G coupe, and to take the drain plug out is next to impossible with the configuration of the install. ATI supplied a syringe and tubing. You trim down the tip of the tube to a tapered spear point, then take a little part of the point off so it does not bend back on itself (the tubing is soft and very flexible), and then jiggle the little devil all the way down to the bottom of the unit. Save the old oil bottle and as you withdraw the used oil, squirt it into the old bottle as a cross check that you get all of the oil out.
It works quite effectively.
Old Dec 27, 2003 | 08:04 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
But what about the little metal flecks? Can you suck them out with this device? Also, you can't clean them off of the magnetic plug with this device either.
Yes Max, time is money but the first one took me like 45 mins. and the second was only about 25 (learning curve).
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
