FS: 4 Liter Surge Tank
Old Jan 25, 2012 | 09:12 PM
08NismoZ's Avatar
08NismoZ
Default 4 Liter Surge Tank
I had this surge tank made so I could run a single big fuel pump for E85 instead of going with the standard CJM twin pump option. It has a -12 outlet to go to the fuel pump, two -8 fittings, and a -6 fitting. I was going to run a -8 line from the OEM fuel tank to the surge tank, -12 line to the inline single pump, -8 return line, and a -6 line going back to the OEM fuel tank as an overflow line.
I would like $250 shipped to the continental 48 states. It has never been used because I am abandoning my build project due to outside issues. There is also tape covering all the fittings to prevent anything from getting inside the tank during storage.
Old Jan 28, 2012 | 06:30 PM
08NismoZ's Avatar
08NismoZ
BUMP!
Old Feb 5, 2012 | 04:33 AM
08NismoZ's Avatar
08NismoZ
Super Bowl BUMP
Old Feb 9, 2012 | 07:42 PM
08NismoZ's Avatar
08NismoZ
Bump!
Old Feb 12, 2012 | 07:30 AM
08NismoZ's Avatar
08NismoZ
Bump!
Old Feb 17, 2012 | 12:23 PM
08NismoZ's Avatar
08NismoZ
Still for sale
Old Feb 22, 2012 | 07:34 AM
08NismoZ's Avatar
08NismoZ
Bump bump
Old Mar 2, 2012 | 01:19 PM
08NismoZ's Avatar
08NismoZ
Open to offers!
Old Mar 7, 2012 | 05:49 AM
08NismoZ's Avatar
08NismoZ
Ttt
Old Mar 16, 2012 | 11:53 PM
08NismoZ's Avatar
08NismoZ
Back from vacation bump!
Old Mar 23, 2012 | 03:33 AM
terrasmak's Avatar
Where does it fit in the car?
Old Mar 23, 2012 | 06:07 AM
08NismoZ's Avatar
08NismoZ
I was going to place it underneath where the spare tire goes. I was going to use 4 rubber mounts and bolt it in the middle. If you have a true dual exhaust then you should have plenty of room right there in between the 2 exhaust pipes. From there you could easily mount am external fuel pump and inline filter, as well as run your overflow line to the driver side of the OEM fuel tank. This surge tank makes it so you don't need to modify your OEM fuel pump housing for a bigger pump or return fuel line
Old Apr 9, 2012 | 06:56 AM
08NismoZ's Avatar
08NismoZ
Still for sale
pslamp32
Feb 8, 2017 09:07 AM
May 12, 2016 07:42 PM
TrackFiddy
Sep 24, 2015 11:40 PM
CJs_Z33
Sep 18, 2015 12:06 PM
