Launching your boosted car?
Old Jan 28, 2012 | 03:53 PM
f150intally's Avatar
f150intally
Djamps, did you bust your axles a lot before getting bias? I'm worried about the dss pro axles being that I have heard of people breaking them.
Old Jan 28, 2012 | 05:37 PM
djamps's Avatar
djamps
I never broke an axle myself (still stock, knock on wood) but I have seen so much carnage with everything from stock to DSS PRO with people running DR's I knew right away not to F around without bias ply's :P. Before bias ply's I ran street tires and had such bad wheel hop I never pushed it too hard. Haven't had a single issue with wheel hop or 'dead hook' syndrome since.
Old Jan 29, 2012 | 07:21 AM
rcdash's Avatar
rcdash
Originally Posted by djamps
I never broke an axle myself (still stock, knock on wood) but I have seen so much carnage with everything from stock to DSS PRO with people running DR's I knew right away not to F around without bias ply's :P. ...
Interesting assessment. Now I understand why:
http://www.dragzine.com/tech-stories...hompson-tires/
However, there are also radial drag tires that have been designed solely for use on the strip. These are used in the ‘legal’ classes of races, such as Stock, Super Stock, and Comp Eliminator, and are used most often in cars equipped with automatic transmissions. Because drag radials dead-hook off the line and are constructed more stiffly than bias-ply tires, they are very unforgiving in regards to regaining traction. Consequently, they also often require much more work to the chassis in order to get the most out of them. So, while radials have several distinct advantages over bias-ply drag tires, they certainly won’t solve all of your on-track traction issues.
Old Jan 29, 2012 | 07:37 AM
konrad's Avatar
konrad
can someone post some links to some bias ply tires. I dont know squat about those tires or where to find them
Old Jan 29, 2012 | 09:41 AM
OldManZ350's Avatar
OldManZ350
Micky Thompson ET Street
http://www.mickeythompsontires.com/s...?item=ETStreet
Attached Thumbnails Launching your boosted car?-screen-shot-2012-01-29-at-1.39.13-pm.jpg
Old Jan 29, 2012 | 09:48 AM
tylerxfire's Avatar
tylerxfire
alot of ppl run 15's and such but honestly i never had a problem with my 17" mickey thompson ET streets (3743) mounted on flix ftd wheels..they ran straight with no slippin around half track because they dont have a huge sidewall and they stuck just fine at my power level and i was on stock axles pullin 1.6 60ft's all day.
Old Jan 30, 2012 | 05:23 AM
djamps's Avatar
djamps
Originally Posted by OldManZ350
+1, ET Streets are pretty much the go-to tire, I love my 26x11.5x16's even with >2deg negative camber they launch like butter. M/T advertises they need little/no burnout but I disagree.. mine don't hook hard off the line and stay straight at the 1/8 unless I do a good 2nd gear burnout.
Even M/T themselves recommend against DR's on manuals.
Old Jan 30, 2012 | 07:41 AM
350zion's Avatar
350zion
Professional
Broke my stock axles first time out on DR's. Launched at about 5k with about ~400hp. Be easy on that launch. Practice pedaling it at first till u get a good feel for ways going on. IMO!
Go out and have some fun.
Old Jan 30, 2012 | 11:02 AM
f150intally
Someone slap me into the original intent of my build - GOING FAST in a straight line. I fell into the brake upgrade trap and did all four corners with the Akebono kit. At the end of the day, I just didn't need them and it really had nothing to do with my original goals. Thank goodness I saved the calipers, old brakes are going back on the rear. I already have a set of very light 16" wheels that fit over the stock brakes just fine. I will swap the rear brakes back out and the run the 26x10.5x16 MT ET Streets as suggested by the drag racing patrons of this website. Will it look dope? Not as dope as the big red calipers that are currently on the back but i will be able to run good tires that meet my goals and get me down the 1320 while lowering the risk of axle carnage
Old Feb 22, 2012 | 11:07 PM
aln's Avatar
aln
Do you run standard diff?
Old Feb 23, 2012 | 02:55 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Before upgrading, I made a number of passes on the stock LSD dif. I later upgraded the dif as one of many steps to battle wheelspin on the street. Also, I piloted an automatic 350Z (which doesn't receive the shock of a 6spd) into the 8's many times on a stock dif. So, from a durability standpoint they are rather tough - but an aftermarket dif will do a better job of planting power.
Old Feb 23, 2012 | 03:12 AM
aln's Avatar
aln
yeah I was just thinking of the putting power to the ground part.
Old Feb 23, 2012 | 05:40 AM
str8dum1's Avatar
str8dum1
lsd isnt going to do much if you dont have proper alignment, tires, and suspension. I;d worry about that last.
Old Feb 25, 2012 | 02:34 PM
RED RIDER's Avatar
RED RIDER
Phil, you just need to take a trip to West Texas in April and you'll never want to 1/4 the car again...just can't beat the feeling of 59 miles over 130mph sustained and then turn around North and do it again an hour later
www.bborr.com < go to this link, click previous races, go to 2009, Grand Sport 125MPH category and look at third place
COME ON APRIL!!!! lol
Old Feb 27, 2012 | 07:54 AM
psychoballistic's Avatar
psychoballistic
Tom, you always have the most tempting events that your attending... I love the 1/4, grew up around it, and finally started getting into it myself. One of these days i'm going to come down there and trailer the car to one of these events with you!
Old Feb 28, 2012 | 01:19 PM
djamps's Avatar
djamps
Stock axles + Bias plies + 5k rpm clutch drop:
http://djlab.com/stuff/djamps_kp.mp3
Did it all day long then drove 120 miles home. Original axles with almost a hundred 1/4 passes and 60k miles.
Old Feb 28, 2012 | 01:52 PM
f150intally
Awesome! sounded like you still had some pretty good wheelspin in first?
Old Feb 28, 2012 | 04:18 PM
  #38
RED RIDER's Avatar
RED RIDER
Would be awesome to have you come down..maybe one day I can afford to make the trip to NC..would love to do that!..Anyhow..2 day trip and yer here! See ya bro!
Old Feb 28, 2012 | 04:54 PM
  #39
djamps's Avatar
djamps
Yea there was some spin because I didn't do a burnout on that run. Stupid track officials making you roll 20 feet past a barely damp water box then sit for over a minute before starting the burnout. I was like F it not even trying.
Learned something though: although there was spin it was controlled spin. Ended up being my best run of the day.
Old Feb 28, 2012 | 05:07 PM
  #40
OldManZ350's Avatar
OldManZ350
That's the nice thing about ET Streets, If you do get some spin, it's a controlled spin. They don't let loose on you and go to redline. And you can control the amount of spin you want by the Air Pressure.
