View Poll Results: Stay na to crash into trees or boost it and do it with style ?
Stick with forced induction
61.54%
Go with a NA build
38.46%
Voters: 13. You may not vote on this poll
Hill Climb to FI or not to FI
Old Mar 1, 2012 | 12:49 AM
Resmarted's Avatar
Resmarted
I don't see an NA v-6 being fun for hillclimb
Old Mar 1, 2012 | 09:16 AM
ace32x's Avatar
ace32x
340+ whp na v6 would be fun for just about anything
Old Mar 1, 2012 | 09:28 AM
str8dum1's Avatar
str8dum1
only if the car was stripped. otherwise it will get outclassed by barely modified turbo 4 bangers.
Old Mar 1, 2012 | 09:46 AM
ace32x's Avatar
ace32x
I would assume it would be if he's in a competitive bracket
Old Mar 1, 2012 | 07:53 PM
nathanwl2004's Avatar
nathanwl2004
Originally Posted by ace32x
this is the only way to go if u go na
http://www.youtube.com/watch?v=9X0WMeaZufo
thats pretty sick dude. that car makes almost as much power NA as my greddy TT z does at 5 PSI and I'll bet it has a better power band. course I bet it cost like 5 times as much but even still.
but yes as was stated earlier, turbos will continue to spool until they produce a target pressure at which point the wastegate controls the boost pressure by bypassing exhaust gas ensuring the turbo spins at just the right speed. as you go higher and higher the air density goes down causing NA and supercharged engines to loose power. with turbo systems however the wastegate stays closed more allowing the turbo to spin a little faster creating the same boost pressure it would have at ground level air density.
Old Mar 2, 2012 | 01:20 PM
Resmarted's Avatar
Resmarted
I doubt you'd have any real torque. Like str8 said, turbo 4cyls would just smash the z.
Up to and sometimes beyond 400whp subies and evos make so much torque, that it's borderline bullsh*t. They go with those small turbos and just have mid range for days. A local guy makes more torque than hp with some basic upgraded turbo in his lil evo 9.
SharX59
Sep 27, 2015 09:23 AM
bluefish
North East
13
Feb 27, 2004 01:41 PM
